M9O OEY Posted June 20, 2010 Share Posted June 20, 2010 Hi When I went to fill up last night it took about 10 mins and 100 presses of the button to open the flap . I cam hear the soleniod operating when I press thebutton nut the flap stays closed anyone got any ideas ? Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted June 20, 2010 Share Posted June 20, 2010 I always have to give mine a few very quick repeat presses .... seems to do the trick Quote Link to comment Share on other sites More sharing options...
Vale Posted June 20, 2010 Share Posted June 20, 2010 Yer, mine was doing this a while back, i ended up taking the spring out and re-bending it a little and then putting some vaseline on the retrackable pin that the soleniod operates.... always opens now Quote Link to comment Share on other sites More sharing options...
tez162003 Posted June 20, 2010 Share Posted June 20, 2010 i had this myself also on the second time off filling up my 350z press - check press - check repeated this like 10 times, i looked like a right muppet, it eventually opened. and since then not been an issue, but i may have to do what was said above and just clean and grease it up. Quote Link to comment Share on other sites More sharing options...
M9O OEY Posted June 20, 2010 Author Share Posted June 20, 2010 Thanks will have a look tomorrow Quote Link to comment Share on other sites More sharing options...
Pimm Posted June 20, 2010 Share Posted June 20, 2010 This has happend to me to, I was on my own and wanted to get to the cap and press the button at the same time it does not happen. Quote Link to comment Share on other sites More sharing options...
michael2516 Posted June 20, 2010 Share Posted June 20, 2010 Yer, mine was doing this a while back, i ended up taking the spring out and re-bending it a little and then putting some vaseline on the retrackable pin that the soleniod operates.... always opens now +1 Quote Link to comment Share on other sites More sharing options...
ThyJones Posted June 21, 2010 Share Posted June 21, 2010 not the same issue, but similar, i pushed the button on the dash to open my petrol cap and pushed the button in... :S If i cant get this back out, how else can you open the petrol cap? or can't you? Quote Link to comment Share on other sites More sharing options...
BladesGrant Posted June 21, 2010 Share Posted June 21, 2010 not the same issue, but similar, i pushed the button on the dash to open my petrol cap and pushed the button in... :S If i cant get this back out, how else can you open the petrol cap? or can't you? I pushed mine through as well, you can easily get access to where you have pushed it through and then replace back into position. If you get down into your footwell you will see it. Quote Link to comment Share on other sites More sharing options...
Ebized Posted June 21, 2010 Share Posted June 21, 2010 Link to a TSB for the fuel filler cap sticking http://www.myzroadster.com/Files/tsbs/0 ... 04-059.htm Used this to fix the problem I had on my first ZED Quote Link to comment Share on other sites More sharing options...
M9O OEY Posted June 21, 2010 Author Share Posted June 21, 2010 Thanks for the replies iv had a go and ended up removing the bloody so called spring I believe the previous owner had the same problem as it was bent out of shape and had plier marks on it Quote Link to comment Share on other sites More sharing options...
