200sx Posted June 18, 2010 Share Posted June 18, 2010 I was changing my spark plugs this afternoon with one of those sockets with a rubber insert to grip the plugs. After tighting up the 3rd plug I pulled the the socket out but the rubber insert stuck on the plug deep inside the cylinder head. Now I can't get a socket back on to remove the plug and I can't fit the coil pack thingy on! Does anybody have any ideas on how to remove the rubber?? Quote Link to comment Share on other sites More sharing options...
Husky Posted June 18, 2010 Share Posted June 18, 2010 extra long nose pliers? im sure you can get really long ones. Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted June 18, 2010 Share Posted June 18, 2010 long nose needle pliers or possibly a pair of chopsticks from the chinese Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted June 18, 2010 Share Posted June 18, 2010 You should be able to get the socket back over the rubber to remove the plug. Failing that you may have to remove the Rocker Cover if it is really jammed but that is highly unlikely. Once the RC is removed you will still have to overcome the spark plug metal tube which is 100 x 25mm. Quote Link to comment Share on other sites More sharing options...
Husky Posted June 18, 2010 Share Posted June 18, 2010 i wouldnt want to be removing the rocker cover unless its really necessary and as alex says you've still got eh tube there anyhow. ball ache indeed Quote Link to comment Share on other sites More sharing options...
200sx Posted June 18, 2010 Author Share Posted June 18, 2010 The problem is when I tried to put the socket back on it pushed the rubber over the hex! What do you mean about removing the rocker cover? Quote Link to comment Share on other sites More sharing options...
200sx Posted June 18, 2010 Author Share Posted June 18, 2010 I don't think I will be able to get thin nosed pliers long enough and thin enough to get down there. I might try pouring some petrol down the tube and try burning it off. Not sure the petrol would burn down there though. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted June 18, 2010 Share Posted June 18, 2010 Your socket will be much stronger than the rubber, just carefully chap it on until you get a grip of the plug. The RC is the cam box on the top of engine. There are two of them, but you will only have to remove one, but like I said previously this should not be necessary. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted June 18, 2010 Share Posted June 18, 2010 I might try pouring some petrol down the tube and try burning it off. Not sure the petrol would burn down there though. I would certainly not recommend that course of action. Quote Link to comment Share on other sites More sharing options...
Husky Posted June 18, 2010 Share Posted June 18, 2010 I don't think I will be able to get thin nosed pliers long enough and thin enough to get down there.I might try pouring some petrol down the tube and try burning it off. Not sure the petrol would burn down there though. EDIT: DO THIS AND FOR **** SAKE TAKE PICTURES Quote Link to comment Share on other sites More sharing options...
200sx Posted June 18, 2010 Author Share Posted June 18, 2010 I have tried knocking the socket on the plug and was hitting it pretty hard too, but still no joy. I really am lost. I could try a long handle on a scalpel?? I can't believe such a simple job lead to a such a big problem Quote Link to comment Share on other sites More sharing options...
Husky Posted June 18, 2010 Share Posted June 18, 2010 the right tool for the job is your friend Quote Link to comment Share on other sites More sharing options...
mic-39 Posted June 19, 2010 Share Posted June 19, 2010 can you not get the socket back onto the plug and screw the plug back out again, remove washer and refit plug this time not using the rubber washer thingy Quote Link to comment Share on other sites More sharing options...
200sx Posted June 19, 2010 Author Share Posted June 19, 2010 I have bought the longest thinest pliers I can find, but still no joy and knackered the ceramic of the plug in the process. mic-39. that is the problem I can't get the socket back on because the rubber is stopping it. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted June 19, 2010 Share Posted June 19, 2010 Quote Link to comment Share on other sites More sharing options...
Ebized Posted June 19, 2010 Share Posted June 19, 2010 If you want to try something else before Alex's hard-hitting approach...... And as the plug is now knackered try a length of wire, say from a coat hanger, with a hooked and spiked end and do a bit of fishing - perhaps a torch might help. Even two hooked wires - one either side to help an even pull the rubber ring off might be better. Just a suggestion Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted June 19, 2010 Share Posted June 19, 2010 If you have already used enough force to have broken the ceramic of the plug, IMO the wort thing you can do is remove the plug, as you will end up with bits of the ceramic section down the bores, so your next job will be to remove the head! I would attempt to cut the rubber ring as much as possible, then find a decent vacuum cleaner and hold it to the top of the plug tube and see if that works. Quote Link to comment Share on other sites More sharing options...
terribleone Posted June 19, 2010 Share Posted June 19, 2010 Loving the petrol & fire idea!! Probably not something that would ever enter my head but hey, some people just like fire!! I'd personally try getting some kind of cable/wire down there...you can't easily grip on the rubber as it's narrow down there for pliers, but some kind of lasso/hook setup might help you 'pull' it back off in the direction it came. Bashing the socket on will only push it on further, and then as mentioned you'll pull the plug out and all the debris from previous attempts is straight into the engine!! Quote Link to comment Share on other sites More sharing options...
helimeddaz Posted June 19, 2010 Share Posted June 19, 2010 I Don't have any sensible ideas, but just listening to all yours got me thinking, once I'd stopped laughing (Even at the genuine suggestion). I know it's not funny, but I couldn't help it. So here my 2 penneth:- 1. Spray lubricant (WD40) or the like into the bore. 2. Blow down the bore with a high pressure air line. The broken bits will fly out and hopefully the rubber ring will come with it. It's that mad it might be pure genius. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted June 19, 2010 Share Posted June 19, 2010 I Don't have any sensible ideas, but just listening to all yours got me thinking, once I'd stopped laughing (Even at the genuine suggestion).I know it's not funny, but I couldn't help it. So here my 2 penneth:- 1. Spray lubricant (WD40) or the like into the bore. 2. Blow down the bore with a high pressure air line. The broken bits will fly out and hopefully the rubber ring will come with it. It's that mad it might be pure genius. Good idea! Provided he owns a compressor of course Quote Link to comment Share on other sites More sharing options...
Husky Posted June 19, 2010 Share Posted June 19, 2010 completely agree with ricky, now you have got bits of broken stuff in there be very carefull Quote Link to comment Share on other sites More sharing options...
Leeroy Posted June 19, 2010 Share Posted June 19, 2010 I'm also loving the fire idea, I should think you're hacked off enough to firebomb the whole car! Don't do it Another leftfield idea might be to fish it out with a REALLY strong fishing hook and some 50lb fishing line Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted June 19, 2010 Share Posted June 19, 2010 telescopic antenna and superglue / blutack / industrial strength glue? Quote Link to comment Share on other sites More sharing options...
Husky Posted June 19, 2010 Share Posted June 19, 2010 stick your willy in the tube Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted June 19, 2010 Share Posted June 19, 2010 stick your willy in the tube i think that would require the bonnet to be removed and possibly the strut brace too Quote Link to comment Share on other sites More sharing options...
