Shaun1982 Posted June 15, 2010 Share Posted June 15, 2010 Bought Fast car earlier as i was bored,theres a detailing bit in it & at the end a list of sites & products blah blah blah Annnyyywwhhooooo this stuffs coming out shortly & i found this on their site http://www.kleers.com/product.php?xProd=10&xSec=2 Just noticed its a bit pricey though Quote Link to comment Share on other sites More sharing options...
tez162003 Posted June 15, 2010 Share Posted June 15, 2010 good quality carbin fibre should have a UV resistant coat on them, but alot of cheap stuff uses marine gels which are not very good or long lasting for automotive use (moral of the story, buy quality carbon items) Quote Link to comment Share on other sites More sharing options...
Zugara Posted June 15, 2010 Share Posted June 15, 2010 Wow... need to be a millionaire for that stuff!!! Quote Link to comment Share on other sites More sharing options...
Shaun1982 Posted June 15, 2010 Author Share Posted June 15, 2010 Zugara check this out then http://valentineswax.com/valentines-car ... nd%20track Quote Link to comment Share on other sites More sharing options...
Envy Valeting Posted June 15, 2010 Share Posted June 15, 2010 Zugara check this out then http://valentineswax.com/valentines-car ... nd%20track Got a full pot of the track and Concours one Paul that I've not tried yet...... Quote Link to comment Share on other sites More sharing options...
Shaun1982 Posted June 15, 2010 Author Share Posted June 15, 2010 Do you use Dodo too? im still using my orange crush on my white zed so ill change at some point.Been looking at the Diamond white is it,hows that compare to the twice as dear Supernatural? Quote Link to comment Share on other sites More sharing options...
350 Russ Posted June 15, 2010 Share Posted June 15, 2010 Zugara check this out then http://valentineswax.com/valentines-car ... nd%20track Thats not too bad i saw a wax on detailing world the other day by chemical guys that was into the thousands! Quote Link to comment Share on other sites More sharing options...
Shaun1982 Posted June 15, 2010 Author Share Posted June 15, 2010 Zymol have a wx thats £40k Quote Link to comment Share on other sites More sharing options...
lilsheepshagga_turbo Posted June 15, 2010 Share Posted June 15, 2010 the diamond white is a fairly good wax. used it plenty on my zed and other white cars that i have cleaned through time. it also has a fairly good finish so 40 quid you cant really go wrong. tbh for not much more u cud use race glaze 55 i think it is... only used it once on my zed and it was fantastic in every department. plus on a rather large test on DW it ranked only behind swisswax B.O.S but if u think 38 quid is to much then forget B.O.S iirc its 120 quid.. im currently using zymol ital, B.O.S and DDSN and tbh they all perform about the same... secret is prep and clean tools my man. so your 40 quid wax will be as good as a 5k wax if your prep is right -ho Quote Link to comment Share on other sites More sharing options...
Lexx Posted June 15, 2010 Share Posted June 15, 2010 Bought Fast car earlier as i was bored,theres a detailing bit in it & at the end a list of sites & products blah blah blah Annnyyywwhhooooo this stuffs coming out shortly & i found this on their site http://www.kleers.com/product.php?xProd=10&xSec=2 Just noticed its a bit pricey though thread hijack, where you on the M1 (possibly the M18) yesterday!? heading North? Quote Link to comment Share on other sites More sharing options...
Shaun1982 Posted June 16, 2010 Author Share Posted June 16, 2010 Cheers for that Ho. Ill bear it in mind when I buy some more then, was maybe goin to buy the supernatural but if the diamond is goin to give similar results ill probably get that. Shame my Orange Crush is still at least 3/4 full still though lol Lexx not me my man, my car didn't move yesterday. Its still got tape across the lights in my attempt to keep the eyebrows attached this time Quote Link to comment Share on other sites More sharing options...
Envy Valeting Posted June 16, 2010 Share Posted June 16, 2010 Do you use Dodo too? im still using my orange crush on my white zed so ill change at some point.Been looking at the Diamond white is it,hows that compare to the twice as dear Supernatural?It'll boil down to durability Shaun.The SN will last longer before you need to top up. Looks wise its in the eye of the beholder. I love the way every ones jumping on wax prices. I have some that are worth £1000's of pounds but if I get asked by enough customers "do you have X wax" then I have to consider it! 1 "expensive" wax only took me a year to earn its keep, that said I did have a £400 pot I bought for my 22b before I decided to do this for a living. Why did I buy it? Well I just wanted the best for my car and its the best I could afford at the time lol. Quote Link to comment Share on other sites More sharing options...
Shaun1982 Posted June 16, 2010 Author Share Posted June 16, 2010 Right lol. After seeing the thread on here with the supernatural i think i might go for that soon Quote Link to comment Share on other sites More sharing options...
Biggy Posted June 16, 2010 Share Posted June 16, 2010 Supernatural is an awesome wax, but don't forget you can buy the panel pots, which gives you a small amount to test out to see if you like it. Quote Link to comment Share on other sites More sharing options...
Andy Barnes Posted June 17, 2010 Share Posted June 17, 2010 Hi, Just noted this thread from our webstats, hope OK to respond to clarify the points raised here Kleers carbon UV Protector is not a wax or temporary solution to UV, its a permanent fix to your carbon parts which is applied only once to give the full protection. The little 50ml bottle is enough to coat a whole bonnet. The product is applied in 3 stages (DIY) and penetrates the surface of the gelcoat to give the protection, it does not lay on the surface like a wax or polish however it does not change the surface or prevent waxing in future. Once applied it lives within the gelcoat with no visual difference. Many manufacturers of carbon apply a certain percentage of UV protection in the products when they are being produced, some dont. Even those which do, there is only a certain level of UV product which can be added to the gelcoat mixture. Its quite common for all the cheaper and ' great priced ' carbon gelcoat parts not to have UV protection installed owing to their very nature, as noted when you look around the event paddocks and its easy to spot cheap products from well engineered ones and all those yellowing carbon parts. The Kleers UV gives protection for those that dont have it and a top up for those that do. Essentially if you are into buying cheaper carbon parts, this will help make those parts look better for longer or preserve your high end parts. The product is priced according to the contents, the chemicals which make up the product are very expensive to start with. As you will note with the rest of the Kleers range, the pricing is very good. This product demands a higher price as a result of its make-up to battle UV, its not a gimmick. Its completely unique to our range. Hope the info is helpful, feel free to ask any other questions FYI we will be at Brands Hatch next weekend ( Modified Live Show on 27th ) with a trade stand and our full range on display- we supoprt the Show and Shine comps. I am aware some members of the club will be attending so if you are, come up and say hello. Kleers is also used by the Nismo Sumo GT1 GTR team as you will see here : http://www.kleers.com/section.php?xSec=8&xPage=1 The GTR's will also be at Brands. Thanks Andy Kleers Products Ltd Quote Link to comment Share on other sites More sharing options...
Shaun1982 Posted June 17, 2010 Author Share Posted June 17, 2010 Hi Andy Thats cool, gives people a better idea of what it actually does now i thought it was just a polishy type product Will you be at Japfest2? Quote Link to comment Share on other sites More sharing options...
Andy Barnes Posted June 18, 2010 Share Posted June 18, 2010 No probs, Ive updated the information on our website too as it wasnt clear enough as to just how special it is. Japfest 2 : I dont think so but we will definately be at JAE, we are supporting the show and shine competition as well as having a trade stand etc. Thanks Andy Quote Link to comment Share on other sites More sharing options...
Shaun1982 Posted June 18, 2010 Author Share Posted June 18, 2010 That's a shame,wouldn't of minded looking at some of the stuff. Maybe a show next year then Quote Link to comment Share on other sites More sharing options...
Walbertonio Posted June 18, 2010 Share Posted June 18, 2010 Quality website btw, a definite bookmark. Quote Link to comment Share on other sites More sharing options...
