BulletMagnet Posted June 14, 2010 Share Posted June 14, 2010 As some of you might know already, I replaced the K1 with a K2. But sadly, my K2 didn't sit right after fitting it to my Zed. So off I went to my local garage to have it adjusted Here you see that the flanges between the mid pipe and backbox are out, causing one pipe to poke out further than the other So it was decided to cut a V out near the flange on the backbox Then apply heat and then bend it into position After we were happy that it was straight enough, out comes the MIG welder Not the best of welds, but I was told that the steel wasn't really that thick and that even budget Bosal exhausts have thicker material But I'm happy with the finished result, this is the best we could do, and I think it's pretty much spot on now Thanks for looking Quote Link to comment Share on other sites More sharing options...
BladesGrant Posted June 14, 2010 Share Posted June 14, 2010 thats great to know, I want to have my K2 adjusting slightly. Although mine doesn't stick out further than the other side its sat a little lower and on the left as you are looking at the rear. Was it an expensive fix? Quote Link to comment Share on other sites More sharing options...
tez162003 Posted June 14, 2010 Share Posted June 14, 2010 so what made you go from the K1 to the K2? Quote Link to comment Share on other sites More sharing options...
BladesGrant Posted June 14, 2010 Share Posted June 14, 2010 so what made you go from the K1 to the K2? Probably because everything was getting quieter and quieter everyday!!! Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted June 14, 2010 Author Share Posted June 14, 2010 thats great to know, I want to have my K2 adjusting slightly. Although mine doesn't stick out further than the other side its sat a little lower and on the left as you are looking at the rear. Was it an expensive fix? Local garage with friendly mechanic and on a day when the supervisor is off........£10 to the mechanics palm Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted June 14, 2010 Author Share Posted June 14, 2010 so what made you go from the K1 to the K2? Probably because everything was getting quieter and quieter everyday!!! WHAT??????? SAY AGAIN!!!!!!!! Quote Link to comment Share on other sites More sharing options...
M13KYF Posted June 14, 2010 Share Posted June 14, 2010 best photos I've seen you take so far Its a shame JapSpeed cant get their act together and get these exhausts to fit properly in the first place. Great solution though. also added to Guides Quote Link to comment Share on other sites More sharing options...
wizard Posted June 14, 2010 Share Posted June 14, 2010 Did you do this yourself!? EDIT, I must have missed both your replied! Quote Link to comment Share on other sites More sharing options...
tez162003 Posted June 14, 2010 Share Posted June 14, 2010 so what made you go from the K1 to the K2? Probably because everything was getting quieter and quieter everyday!!! WHAT??????? SAY AGAIN!!!!!!!! agreed. huh? Quote Link to comment Share on other sites More sharing options...
xStric9x Posted June 14, 2010 Share Posted June 14, 2010 Omg, its deja vu. Japspeed still haven't sorted this problem out? I was thinking of going back to a k2 myself but after reading this thread definately not. I'm certainly not prepaired to spend that amount of money only to go and start hacking it to pieces to get it to fit properly. Poor show Japspeed Good right up though Bulletmagnet Quote Link to comment Share on other sites More sharing options...
CardShark Posted June 15, 2010 Share Posted June 15, 2010 I'm speaking to Japspeed at the moment about sorting out my K2, when fitted it looked exactly like the OP's. I originally chose it on the basis that although there were a few wonky ones being sent out from them earlier they had since got it right, my exhaust was fitted a couple of weeks ago and it appears that it deffinately isn't. Not happy as it makes a lovely sound, but I fear that if Japspeed can't sort this out for me I'll be asking for my money back and I'll be back on the market for a different set up. Quote Link to comment Share on other sites More sharing options...
was8v Posted January 16, 2012 Share Posted January 16, 2012 THREAD REVIVAL! I just fitted a Japspeed K2 to my car, and it is slightly wonky just like BulletMagnets car. I asked my supplier and they told me there was a 6 month period where Nissan made a slight change to the exhaust. Not sure if that is true or not, but mine is also an 04 plated UK car liked BulletMagnet. CarShark / others with wonky Japspeed - what age are your cars? Quote Link to comment Share on other sites More sharing options...
Lexx Posted January 16, 2012 Share Posted January 16, 2012 Japspeed exhausts have failed to fit 350z cars throughout the entire MY range. It's down to build quality and not the cars themselves. Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted January 16, 2012 Author Share Posted January 16, 2012 Don't believe what JapSpeed tell you. I mean really? Next thing you know is that JapSpeed make suspension that bottoms out all the time and then blaming your local council for building the roads too high... Quote Link to comment Share on other sites More sharing options...
was8v Posted January 16, 2012 Share Posted January 16, 2012 Ah well, mine was just advertised as a "stainless 350z exhaust" and I paid £140 delivered for it brand new. When it turned up in a JapSpeed box I thought "here we go" after reading on here but I had to fit it as I needed the car. Mines not quite as wonky as BulletMagnets so I'm still quids in if I have to get it welded. Quote Link to comment Share on other sites More sharing options...
ianphampton Posted January 16, 2012 Share Posted January 16, 2012 My K2 had pretty much the same issue (though maybe not quite as bad) We were able to overcome mine by bending the hangers and also fitted a clamp block on the offside rear hanger arm which pushed the offside back about 15mm and so the slashcut ends were then parallel Japspeed reputation is pretty well known, though, and if you're paying £349 for the exhaust, you don't expect the same quality as if you're paying £600 or more. I bought it expecting to have some fitment adjustments - and I wasn't disappointed! Quote Link to comment Share on other sites More sharing options...
was8v Posted January 16, 2012 Share Posted January 16, 2012 I'd be pretty upset if I'd paid £350 for this fitment. At the £140 I paid its vaguely acceptable. Quote Link to comment Share on other sites More sharing options...
L4V15 Posted January 17, 2012 Share Posted January 17, 2012 I'd be pretty upset if I'd paid £350 for this fitment. At the £140 I paid its vaguely acceptable. You got your from that 2fast something or other seller on ebay didnt you? I just got one cheap from them too. Had it fitted last week but was well out of shape originally. Hangs a bit low still now. They told me the exact same thing about the 6months different exhaust rubbish. Mines a 54plate Decemeber 2004. Got them to refund me £20 towards having it adjusted. Better than nothing,lol Quote Link to comment Share on other sites More sharing options...
was8v Posted January 18, 2012 Share Posted January 18, 2012 I'd be pretty upset if I'd paid £350 for this fitment. At the £140 I paid its vaguely acceptable. You got your from that 2fast something or other seller on ebay didnt you? I just got one cheap from them too. Had it fitted last week but was well out of shape originally. Hangs a bit low still now. They told me the exact same thing about the 6months different exhaust rubbish. Mines a 54plate Decemeber 2004. Got them to refund me £20 towards having it adjusted. Better than nothing,lol yep! Quote Link to comment Share on other sites More sharing options...
TomS Posted January 18, 2012 Share Posted January 18, 2012 Got a K2 on my 54 zed, fitment was fine until I added HFC's then it was wonky. Garage made adjustments to the hangers rather than the actual exhaust so it sits much better now. Quote Link to comment Share on other sites More sharing options...
