un1eash Posted June 12, 2010 Share Posted June 12, 2010 Not even had my 350Z for 2 weeks yet and ive already started my audio install. I got the fascia and iso loom with steering wheel controls from sextons and installed my Alpine CDA-9886R headunit yesterday.... Steering wheel controls work great and the phone buttons are now used to changed source and folders. My next plan is to see what my Alpine PXA-H100 Processor will make of the bose system if i try and Imprint it. Eventually i'll be putting my JL 6.5" Components in the front doors and will run them of my JL 300/2 Slash Amp. I also have a JL 10w6v2 subwoofer which will be going in a custom sealed box under the strut bar, this will run of a JL 500/1 Slash Amp. Quote Link to comment Share on other sites More sharing options...
Zugara Posted June 12, 2010 Share Posted June 12, 2010 Could you post or pm what items you have used plz. Looking to do this myself. Also does the voice over from the navigation system overcome the volume of the music? Quote Link to comment Share on other sites More sharing options...
ikarus Posted June 13, 2010 Share Posted June 13, 2010 Sounds like a nice quality install you have planned Quote Link to comment Share on other sites More sharing options...
un1eash Posted June 13, 2010 Author Share Posted June 13, 2010 Sounds like a nice quality install you have planned Compared to your install this is my mini JL install. I may replace the rears aswell with some JL's depending on how i like the sound with just fronts. I used the fascia and iso loom that was recommended in the sticky... http://www.sextonsdirect.co.uk/facia_pa ... 0-306.html http://www.sextonsdirect.co.uk/steering ... 9-674.html At the moment i have lost sat nav sound but will looking at wiring it into the Aux input my headunit has, i can then switch to this source to have sat nav sound when needed which isnt very often at all. Quote Link to comment Share on other sites More sharing options...
un1eash Posted June 13, 2010 Author Share Posted June 13, 2010 I had an hour spare before lunch so i wired up the sat nav to the aux input on my headunit. I now have sat nav sound with an aftermarket headunit. The way i did it was my headunit has an aux input lead with twin phonos. I seperated these out and connected them to the sat nav plug. You use pins 18,19,20. 18 - Navi Earth 19 - Navi Input (-) 20 - Navi Input (+) I'm happy with this solution as i use sat nav maybe a couple times a year. Quote Link to comment Share on other sites More sharing options...
un1eash Posted July 1, 2010 Author Share Posted July 1, 2010 Not the tidiest install but it does the job, my JL 300/2 and 500/1 amps... And the awesome sounding JL 10w6v2 I'm still running the stock rears as after Imprinting the system it sounds very good. Quote Link to comment Share on other sites More sharing options...
yokomo Posted July 1, 2010 Share Posted July 1, 2010 nice , just need to sort that sub box out . Quote Link to comment Share on other sites More sharing options...
un1eash Posted July 1, 2010 Author Share Posted July 1, 2010 It was a temp thing for now and does the job well. The box was slot ported and taller, i had it made for my Z4 to JL's exact spec, to get it to fit i had to reduce the height and volume so its now sealed. I'm not big on looks when it comes to audio, no one see's it Quote Link to comment Share on other sites More sharing options...
Biggy Posted July 1, 2010 Share Posted July 1, 2010 why not get a offcut of sheeted carbon fibre, and cut it to the shape of under the brace, and mount it to the sub box, cut out the hole for sub, job done. Quote Link to comment Share on other sites More sharing options...
un1eash Posted July 1, 2010 Author Share Posted July 1, 2010 why not get a offcut of sheeted carbon fibre, and cut it to the shape of under the brace, and mount it to the sub box, cut out the hole for sub, job done. I was going to do this but with carpet, i have the carpet but no wood. I was going to get a new box made with the hole in the middle but the guy who does them went on holiday and i couldnt wait. Quote Link to comment Share on other sites More sharing options...
