350zpete Posted June 12, 2010 Share Posted June 12, 2010 Hi guys i have now replaced both drop links and the passanger side banana bar and the knocking and banging is still there Anymore ideas?? Im cracking up now!!! Quote Link to comment Share on other sites More sharing options...
Mark@Abbey m/s Posted June 12, 2010 Share Posted June 12, 2010 have you tried running the car will both roll bar links disconnected? can you borrow another pair of front shocks? Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted June 12, 2010 Share Posted June 12, 2010 Where you based? If you want front suspension to try let me know but you will need to be darn sarf! Quote Link to comment Share on other sites More sharing options...
350zpete Posted June 12, 2010 Author Share Posted June 12, 2010 HI Guys ive got the problem of the knocking now sorted! I went round and tightened all the nuts etc up again and there was slight moement in the rear nut! Now this is cured ive now another problem!!! There is now vibration coming throught the steering wheel and the steering doesnt feel as solid as it used to!! The problem has onlt happened since i changed the banana bar! HELP! Quote Link to comment Share on other sites More sharing options...
alessandro Posted June 12, 2010 Share Posted June 12, 2010 could this be an allignement/geometry issue? Quote Link to comment Share on other sites More sharing options...
350zpete Posted June 14, 2010 Author Share Posted June 14, 2010 Got it sorted! Thanks to zmanalex once again! It turned out that there may have been something trapped behind the brake disc when i had it off!! I took it off and re installed it and its all working fine! Cheers lads! Pete Quote Link to comment Share on other sites More sharing options...
M13KYF Posted June 14, 2010 Share Posted June 14, 2010 Got it sorted! It turned out that there may have been something trapped behind the brake disc when i had it off!! easy! Quote Link to comment Share on other sites More sharing options...
