rawbhp Posted June 7, 2010 Share Posted June 7, 2010 Where is the best/cheapest place to get some G101 and Bilberry/Autosmart wheel cleaner from? I have PM'd Envy without success. Do people recommend Bilberry over the other wheel cleaners available? I want something that requires minimal effort as I have 19" multi-spoke wheels! Quote Link to comment Share on other sites More sharing options...
alessandro Posted June 7, 2010 Share Posted June 7, 2010 Still haven't seen your wheels Have you tryed Andy @ Kudos Quote Link to comment Share on other sites More sharing options...
350 Russ Posted June 7, 2010 Share Posted June 7, 2010 i recently bought some Premium Blue Rim & Wheel Cleaner and the stuff is absolutly brutal! i would recomend it but make sure its well diluted! i got it from Cleanyourcar.co.uk Quote Link to comment Share on other sites More sharing options...
ChrisS Posted June 7, 2010 Share Posted June 7, 2010 I use bilberry at 10:1 just sray it on ,go for a brew and then brush and rinse. Got mine from Valepro,think monza do it and if you spend over £40 it's post free + 2 free micro fibre cloths. Quote Link to comment Share on other sites More sharing options...
Vik54 Posted June 7, 2010 Share Posted June 7, 2010 I use bilberry at 10:1 just sray it on ,go for a brew and then brush and rinse.Got mine from Valepro,think monza do it and if you spend over £40 it's post free + 2 free micro fibre cloths. Even at 10:1 I wouldn't leave Bilberry unattended - it is serious stuff I bought some last year - used it a couple of times and now it lives under the sink but TBH I find my shampoo (PB super slick suds) that's left in the bucket does just fine and its gentler Quote Link to comment Share on other sites More sharing options...
Clb Ltd Posted June 7, 2010 Share Posted June 7, 2010 Any Wheel cleaner that requires minimum effort is not good for your wheels. I would never advise you to leave any wheel cleaner to dwell for more than a few mins. These are wheel cleaners I would recommend they are all acid free. I would just like to mention that any cleaner if left to dwell for to long acid free, alkaline free ect, may damage what it has been applied to. 1. Bilberry 2. Mellow Yellow - Dodo Juice 3. Custom Wheels - Autoglym 4. Clb Wheel Cleaner (not yet on sale) This is the process I would recommend it may seem long winded but well worth it in the end. The cleaning process once you have followed these few easy steps will be minimal. 1. Clean wheels using your preferred wheel cleaner (Spray one wheel agitate then spray another wheel agitate, and then go back to the first wheel and remove the wheel cleaner with a PH neutral shampoo. Repeat this process until you are happy with the results. The shampoo will neutralize the wheel cleaner) 2. Clay bar your wheels to remove any bonded contamination. 3. Polish with your preferred polish to remove and clay lube residue and to clean and revive the shine. 4. Seal wheels with a wheel sealant recommended Wheel Sealants (1) Bilberry Wheel sealant (2) RimWax Now you have thoroughly cleaned and sealed your wheels you will need to dilute your wheel cleaner to the highest dilution rate or more as you do not want the wheel cleaner to break the wheel sealant down. The wheel sealant will prevent any contamination from bonding to your wheels. When the contamination starts to bond to the wheels you need to polish and reapply the wax. I hope this helps Carmen Quote Link to comment Share on other sites More sharing options...
Dblock Posted June 8, 2010 Share Posted June 8, 2010 I use i4detailings stuff. None acidic and great. Quote Link to comment Share on other sites More sharing options...
maz0 Posted June 8, 2010 Share Posted June 8, 2010 Yeah be careful with the harsh stuff, I get the feeling its damaged one of my wheels :S Quote Link to comment Share on other sites More sharing options...
ChrisS Posted June 8, 2010 Share Posted June 8, 2010 Any Wheel cleaner that requires minimum effort is not good for your wheels. I would never advise you to leave any wheel cleaner to dwell for more than a few mins. These are wheel cleaners I would recommend they are all acid free. I would just like to mention that any cleaner if left to dwell for to long acid free, alkaline free ect, may damage what it has been applied to. 1. Bilberry 2. Mellow Yellow - Dodo Juice 3. Custom Wheels - Autoglym 4. Clb Wheel Cleaner (not yet on sale) This is the process I would recommend it may seem long winded but well worth it in the end. The cleaning process once you have followed these few easy steps will be minimal. 1. Clean wheels using your preferred wheel cleaner (Spray one wheel agitate then spray another wheel agitate, and then go back to the first wheel and remove the wheel cleaner with a PH neutral shampoo. Repeat this process until you are happy with the results. The shampoo will neutralize the wheel cleaner) 2. Clay bar your wheels to remove any bonded contamination. 3. Polish with your preferred polish to remove and clay lube residue and to clean and revive the shine. 4. Seal wheels with a wheel sealant recommended Wheel Sealants (1) Bilberry Wheel sealant (2) RimWax Now you have thoroughly cleaned and sealed your wheels you will need to dilute your wheel cleaner to the highest dilution rate or more as you do not want the wheel cleaner to break the wheel sealant down. The wheel sealant will prevent any contamination from bonding to your wheels. When the contamination starts to bond to the wheels you need to polish and reapply the wax. I hope this helps Carmen Sorry for thread hijack.............Nice to see you on board Carmen. Quote Link to comment Share on other sites More sharing options...
rawbhp Posted June 8, 2010 Author Share Posted June 8, 2010 Great advice, and very thorough-thanks May just go for AG custom wheel cleaner as I can pick it up down the road Quote Link to comment Share on other sites More sharing options...
Envy Valeting Posted June 9, 2010 Share Posted June 9, 2010 Hi Rich, I apologise for the slow reply You PM'd me on the 6th June and I replied on the 7th.... Sadly I detail all over the place, have an online shop and also a family and dont get as much time to sit "laptop at the ready" as much as I'd like. Best wishes Tim Quote Link to comment Share on other sites More sharing options...
M13KYF Posted June 9, 2010 Share Posted June 9, 2010 got my bilberry from i4detailing with the forum discount Quote Link to comment Share on other sites More sharing options...
Husky Posted June 9, 2010 Share Posted June 9, 2010 Any Wheel cleaner that requires minimum effort is not good for your wheels. I would never advise you to leave any wheel cleaner to dwell for more than a few mins. These are wheel cleaners I would recommend they are all acid free. I would just like to mention that any cleaner if left to dwell for to long acid free, alkaline free ect, may damage what it has been applied to. 1. Bilberry 2. Mellow Yellow - Dodo Juice 3. Custom Wheels - Autoglym 4. Clb Wheel Cleaner (not yet on sale) This is the process I would recommend it may seem long winded but well worth it in the end. The cleaning process once you have followed these few easy steps will be minimal. 1. Clean wheels using your preferred wheel cleaner (Spray one wheel agitate then spray another wheel agitate, and then go back to the first wheel and remove the wheel cleaner with a PH neutral shampoo. Repeat this process until you are happy with the results. The shampoo will neutralize the wheel cleaner) 2. Clay bar your wheels to remove any bonded contamination. 3. Polish with your preferred polish to remove and clay lube residue and to clean and revive the shine. 4. Seal wheels with a wheel sealant recommended Wheel Sealants (1) Bilberry Wheel sealant (2) RimWax Now you have thoroughly cleaned and sealed your wheels you will need to dilute your wheel cleaner to the highest dilution rate or more as you do not want the wheel cleaner to break the wheel sealant down. The wheel sealant will prevent any contamination from bonding to your wheels. When the contamination starts to bond to the wheels you need to polish and reapply the wax. I hope this helps Carmen Great info Quote Link to comment Share on other sites More sharing options...
