dt350z Posted June 4, 2010 Share Posted June 4, 2010 first things first does some one on the forum do an uprated clutch kit. secondly are they any good. thirdly has anyone fitted one them self and are they fairly easy to fit for a clutch. dan Quote Link to comment Share on other sites More sharing options...
Vik54 Posted June 4, 2010 Share Posted June 4, 2010 You can buy them here viewtopic.php?f=38&t=27436 But depends if you want lightweight fly ...if Fidanza isn't for you then stock replacement is LUK also available from zmanalex Plenty of posts about pros and cons of uprated clutch and flywheel and discussions if you should even replace flywheel when you do the clutch - general consensus is 'yes' Have a search around in the Technical boards - you will find plenty info there Haven't a clue about fitting Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted June 4, 2010 Share Posted June 4, 2010 You have pm Dan. Quote Link to comment Share on other sites More sharing options...
