Removing drivers side door handle
matty316
have you read the guide?
did you undo all 3 bolts on the drivers side?
only 2 on the passenger
also there is a little clip at the bottom which the gets stuck a little on the door panel (only sticks out about 5 mm) when removing.
:scare:
I was going to do mine at the weekend... hope its not a real biatch :dry:
outs easy :lol: putting it back in can be annoying; nearly though mine through the neighbours window :lol:
if you have a problem tarmac ring me and i'll talk you through it.
easy when you've done it a couple of times
:scare:
Cheers bud :thumbs: Any luck finding a new motor :shrug:
