my clutch peddle is sticking on return as in when i take my foot off it returns three quarters the way then sticks for a min then pops back. it just started today could it be the clutch linkage?
has anybody experienced this & offer any advice?
thanks matt (wide)
thanks matt (wide)
A new clutch slave cyl. and flush out the fluid and bleed will fix your issue.
Clutch slave cyls in stock and good to go same/next day £73.00. :thumbs:
Alex :)
mine does this too but only once in a blue moon, thought it maybe where the cars been standing for a while :shrug: . and the fact my thrust brearing is on its way out.
might be the hot weather and also if you pushed the car hard. mine did it once on a track day. stuck to the floor and took lots of pressing to get it up.
most likely like said above it will be the clutch slave cylinder.
Zmanalex has all you need
Ours did that after sitting for a week or so. Took it out on one of the hottest days last week. After a wee bit shopping, heading home and low and behold ours did the same... About 20mins later and alot of pedal lifting incase i burnt the clutch the pedal was fine.. Never had an issue since.
It had a major service today (ouch) which included bleeding and putting new fluid in...
The garage only heard one other motor doing the same and they couldn't fault it...
Ours was checked today and again couldn't be faulted... It was a 20 min glitch..
Still great car though...
Simboy
