Replacment Of Rocker Cover Gasket (Help needed)
AlexZ
Evening guys, Ive noticed my car using a little more oil than normal...When I changed my plugs a few months back I noticed on the passanger side head there was a little oil leak.
I stripped the car back today and its defo coming from that rocker/cam cover gasket. I've read the manual and it recommends the replacement of the Rocker Gasket, the middle gasket between the upper and lower Intake manifold collector and the gasket between the lower intake manifold collector and the intake manifold itself...
If anyone has done this before I would be grateful off any advise...
I'll get the gaskets ordered asap and get this sorted.
Thanks
Thanks
If the oil leak is definately coming from the cam box gasket then all you will have to replace is the cam box gasket. :thumbs:
I have these in stock and they are priced at £11.00 each.
Same/next day shipping.
Drop me a pm if I can help you further. :)
Alex.
I do have oil on the plug nearst the bulk head on the passanger side. Are you saying theres a gasket on the rocker cover and another separate one as shown in the image?
There is an oil seal in the cam cover (one for each plug)
These oil seals are not available on there own as they are part of the cover.
Alex.
Alex.
What symptoms say that these seals are gone Alex ? I'm using (burning ?) a bit more oil recently
Alex.
Hi Alex, I guess there like o rings round every plug then? Whats the cost for the replacement cover? I guess I'd need both cover and the cover gasket if I'm going to swap the cover?
Alex
Alex.
Alex
You will have pm shortly.
Alex.
Hi mate, I noticed oil around the plug when I changed them a couple of months back....Ive topped the oil up and its gone dows again. These a lot of oil around the plug hole on that cover, Ive done a compression test and all cyclinders are very close, the filter isnt leaking nor the sump plug. The only place I can see oil is around the cam cover. Not sure which seal it is at the mo but I guess i'll find out when I take the cover off lol...
Alex
