showtime1 Posted May 31, 2010 Share Posted May 31, 2010 whats the widest tyre i can put on the rear, ive got standard wheels 8.5 inches, i know alot of you go 265 and 275 cheers. Quote Link to comment Share on other sites More sharing options...
rich5259 Posted May 31, 2010 Share Posted May 31, 2010 most people with 275s are running 19" rims with 35% aspect ratio and 9" or 9.5" rim width 275/40 r 18 is only 1 mm different to standard diameter, so if your fitter is happy to put them on they should be ok (they might look a bit flat due the the extra width sitting on the standard rim) Quote Link to comment Share on other sites More sharing options...
showtime1 Posted May 31, 2010 Author Share Posted May 31, 2010 PROBALLY DONT WANT TO GO TOO WIDE THINKING 255 45 18 OR 265 45 18 Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted May 31, 2010 Share Posted May 31, 2010 PROBALLY DONT WANT TO GO TOO WIDE THINKING 255 45 18 OR 265 45 18 265 would need a 9" rim 255 18 45 would give a 1.33% difference any change at the rear may need to be compensated by a change at the front so as not to affect the lsd Check here http://www.alloywheels.com/tyrecalc.asp Quote Link to comment Share on other sites More sharing options...
Husky Posted May 31, 2010 Share Posted May 31, 2010 best bet is go for a tyre suited to the rim, better to go for the correct tyre than an oversized one or you will actually lose handling. in the case of the standard rays its 245 Quote Link to comment Share on other sites More sharing options...
