Ian Posted May 25, 2010 Share Posted May 25, 2010 After recieving *some* criticism for my interior, I decided to strip it out & start again No pictures from last night because I forgot But I removed the headunit, all the wiring is tucked away neatly & now the headunit fits perfectly. I fed through the wiring for my boost gauge, oil pressure gauge & IC temp monitor. I also replaced my black vacuum hoses with blue ones Wiring for IC monitor neatly hidden away Defi boost sensor Headunit refitted Current state This was just after I wired in the IC monitor, I wont show pics of my soldering job - it might push Husky over the edge IC monitor fitted Just waiting for my new dremel bits to arrive so that I can attack the gear shift surround and fit it there Defi gauges fitted into stock pods Hopefully I will be finished by the end of the week for the Chillis open day Quote Link to comment Share on other sites More sharing options...
Cragus Posted May 25, 2010 Share Posted May 25, 2010 Tidy! Quote Link to comment Share on other sites More sharing options...
JAMIE MOY Posted May 25, 2010 Share Posted May 25, 2010 Quote Link to comment Share on other sites More sharing options...
choptop Posted May 25, 2010 Share Posted May 25, 2010 Should be quite a babe magnet when it is all finished Quote Link to comment Share on other sites More sharing options...
Pimm Posted May 25, 2010 Share Posted May 25, 2010 about 8loody time to if you ask me Quote Link to comment Share on other sites More sharing options...
Ian Posted May 25, 2010 Author Share Posted May 25, 2010 Should be quite a babe magnet when it is all finished IF it gets finished, it will be about 8loody time to if you ask me Its only been about 6months Quote Link to comment Share on other sites More sharing options...
Ian Posted May 27, 2010 Author Share Posted May 27, 2010 Only a small update Got my new dremel collar today so I could finally cut a hole in my centre console Fitted my Nardi handbrake, I've got a Bride boot for it now awell Ive also cut a hole in my cubby hole so that I can put the defi controller in there & hide the wires away I'm also looking for a blanking plate to replace the heated seat switches if anyone has one Quote Link to comment Share on other sites More sharing options...
Husky Posted May 27, 2010 Share Posted May 27, 2010 soldering not done right Quote Link to comment Share on other sites More sharing options...
Ian Posted May 27, 2010 Author Share Posted May 27, 2010 It is done "right", it works Quote Link to comment Share on other sites More sharing options...
Husky Posted May 27, 2010 Share Posted May 27, 2010 It is done "right", it works Quote Link to comment Share on other sites More sharing options...
maz0 Posted May 27, 2010 Share Posted May 27, 2010 Are you quite slobbery when you drive? your plastics look like they have saliva on them Must be the SC Quote Link to comment Share on other sites More sharing options...
Ian Posted May 27, 2010 Author Share Posted May 27, 2010 Are you quite slobbery when you drive? your plastics look like they have saliva on them Must be the SC Just a few marks on them cheap plastics Quote Link to comment Share on other sites More sharing options...
Husky Posted May 27, 2010 Share Posted May 27, 2010 Are you quite slobbery when you drive? your plastics look like they have saliva on them Must be the SC funniest thing ive heard in ages Quote Link to comment Share on other sites More sharing options...
Ian Posted May 28, 2010 Author Share Posted May 28, 2010 A few pics from tonights work. Before any smartarse asks, there is no slobber on my interior Its super lemon cockpit shine (alothough after using it, I'm sure theres a typo in the last word ) Just a few small jobs left now Relocate scangauge Tidy up wiring under drivers side Fit IC monitor probes Fit oil pressure sensors Fit oil cooler Fix my stupid horn problem Quote Link to comment Share on other sites More sharing options...
Husky Posted May 28, 2010 Share Posted May 28, 2010 redo dials to red to match Quote Link to comment Share on other sites More sharing options...
Ian Posted May 28, 2010 Author Share Posted May 28, 2010 redo dials to red to match Ready when you are Quote Link to comment Share on other sites More sharing options...
Husky Posted May 28, 2010 Share Posted May 28, 2010 redo dials to red to match Ready when you are bugger Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted May 28, 2010 Share Posted May 28, 2010 Looking very Quote Link to comment Share on other sites More sharing options...
