Tricky-Ricky Posted May 18, 2010 Share Posted May 18, 2010 Would anyone happen to know this, and number of splines if pos? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted May 19, 2010 Share Posted May 19, 2010 Would anyone happen to know this, and number of splines if pos? Top or bottom? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 19, 2010 Author Share Posted May 19, 2010 Would anyone happen to know this, and number of splines if pos? Top or bottom? Sorry should have said, top! Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted May 19, 2010 Share Posted May 19, 2010 Would anyone happen to know this, and number of splines if pos? Top or bottom? Sorry should have said, top! 33 Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 19, 2010 Author Share Posted May 19, 2010 Would anyone happen to know this, and number of splines if pos? Top or bottom? Sorry should have said, top! 33 Is that splines of dia Alex? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted May 19, 2010 Share Posted May 19, 2010 33 is the number of splines. The diameter of the shaft varies as it is tapered The spline part is 15.27mm - 15.30mm The smooth shaft thereafter is 15.50mm - 17.96mm Quote Link to comment Share on other sites More sharing options...
M13KYF Posted May 19, 2010 Share Posted May 19, 2010 The smooth shaft thereafter is 15.50mm - 17.96mm Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 19, 2010 Author Share Posted May 19, 2010 33 is the number of splines. The diameter of the shaft varies as it is tapered The spline part is 15.27mm - 15.30mm The smooth shaft thereafter is 15.50mm - 17.96mm Thanks mate your a star Quote Link to comment Share on other sites More sharing options...
