ben p Posted May 12, 2010 Share Posted May 12, 2010 What width of tyre will fit on a 18" ray's alloy on the rear of an 06 coupe? the only reason I ask is i've found some 255's cheaper then 245's. And would It be beneficial or detrimental to put wider tyres on?? Thanks guys. Quote Link to comment Share on other sites More sharing options...
marzman Posted May 12, 2010 Share Posted May 12, 2010 Altering the width will affect the height of the tyre, thus affecting the rolling radius, and then causing very annoying TCS problems. So i'd definitely stick with the standard sizes. Quote Link to comment Share on other sites More sharing options...
ben p Posted May 12, 2010 Author Share Posted May 12, 2010 Sounds good, thanks for the advice! Quote Link to comment Share on other sites More sharing options...
busa1300 Posted May 12, 2010 Share Posted May 12, 2010 If the profile of the 255 is 40 the rolling radius will be the same. Quote Link to comment Share on other sites More sharing options...
Ekona Posted May 12, 2010 Share Posted May 12, 2010 busa1300 said: If the profile of the 255 is 40 the rolling radius will be the same. No it won't, it'll be 2.4% smaller. Profile is a percentage of the width, don't forget. Quote Link to comment Share on other sites More sharing options...
Dblock Posted May 12, 2010 Share Posted May 12, 2010 Ekona said: busa1300 said: If the profile of the 255 is 40 the rolling radius will be the same. No it won't, it'll be 2.4% smaller. Profile is a percentage of the width, don't forget. what if you made both tyres 2.4% smaller front and back, would that mean the there would be no tcs issue? Quote Link to comment Share on other sites More sharing options...
Husky Posted May 12, 2010 Share Posted May 12, 2010 Dblock said: Ekona said: busa1300 said: If the profile of the 255 is 40 the rolling radius will be the same. No it won't, it'll be 2.4% smaller. Profile is a percentage of the width, don't forget. what if you made both tyres 2.4% smaller front and back, would that mean the there would be no tcs issue? i would say that is a logical assumption, i will report back after wales Quote Link to comment Share on other sites More sharing options...
Ekona Posted May 12, 2010 Share Posted May 12, 2010 Tbh I wouldn't expect an issue with running tyres that little out of spec anyway: Certainly dropping to 40 profile with the R888s has made no difference to the TCS that I can tell so far. Quote Link to comment Share on other sites More sharing options...
rich5259 Posted May 12, 2010 Share Posted May 12, 2010 Husky said: Dblock said: Ekona said: busa1300 said: If the profile of the 255 is 40 the rolling radius will be the same. No it won't, it'll be 2.4% smaller. Profile is a percentage of the width, don't forget. what if you made both tyres 2.4% smaller front and back, would that mean the there would be no tcs issue? i would say that is a logical assumption, i will report back after wales or I'll report back that Husky has parked in a ditch Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted May 12, 2010 Share Posted May 12, 2010 i know what husky is fitting and i think we'll all know when he's driving as the planet will spin quicker they'll have that much grip they'll be resurfacing the roads behind him Quote Link to comment Share on other sites More sharing options...
