mc Posted May 6, 2010 Share Posted May 6, 2010 I know most cars seem to do this to some extent, but my gear lever seems to move forwards and back quite a bit when going on and off the throttle. Also, at higher speeds, there's a bit of vibration through the gear stick. Would there be a bush thats worn somewhere that's likely to cause these symptoms, or any mountings I can replace that would stop/reduce it (without transmitting too much vibration to the cabin)? cheers mike Quote Link to comment Share on other sites More sharing options...
MacW Posted May 6, 2010 Share Posted May 6, 2010 Vibration I'm pretty sure is normal, I know mine does it and if I remember right the original Evo reviewer of the Z affectionately named theirs the ginger tingler due to it. Not sure on the play during throttle changes tho, not something I've noticed myself. Quote Link to comment Share on other sites More sharing options...
350ash Posted May 6, 2010 Share Posted May 6, 2010 To quote EVO's 350Z buying guide: "on cars up to 2005 the 'lever can vibrate noticeably (in fact during our 2003 Car of The Year test the Sunset Bronze car we had became known as 'the Ginger Tingler' for this very reason). It's not a fault - they were left this way to avoid damping out some of the feel. You soon get used to it." To me it sounds like what you've got is quite typical for the car, think of it as a 'feature' rather than a problem and you'll be fine! Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted May 6, 2010 Share Posted May 6, 2010 Mine is a brushed aluminium tingled and yes there is a noticable little movement back and forward with throttle on and off, I find it quite theraputic if I have my hand rested on my knob Quote Link to comment Share on other sites More sharing options...
mc Posted May 6, 2010 Author Share Posted May 6, 2010 I guess I've got a Ginger Tingler then! thanks for the replies, as long as its not a problem then I'm not bothered! Quote Link to comment Share on other sites More sharing options...
