andlid Posted May 5, 2010 Share Posted May 5, 2010 Hello, Could we get a quote button + - after each post in a thread? so if you wanted to reply to a thread you could do that for all posts you want instead of manual copy or the lazy option to post more times? It would work as you quote and then when you hit reply you get all the quoted posts. A Quote Link to comment Share on other sites More sharing options...
M13KYF Posted May 5, 2010 Share Posted May 5, 2010 there is a quote button in the top right corner of each post. The forum software limits the number of quotes anyway so you do not want to many otherwise you spend ages downloading repeated material Quote Link to comment Share on other sites More sharing options...
andlid Posted May 5, 2010 Author Share Posted May 5, 2010 there is a quote button in the top right corner of each post. The forum software limits the number of quotes anyway so you do not want to many otherwise you spend ages downloading repeated material hmm meant that when you hit the quote button instead of getting into the reply it adds it as a + and then when you hit the REPLY button it uses the ammount of quotes you decided to reply to if you know what I mean? Quote Link to comment Share on other sites More sharing options...
M13KYF Posted May 5, 2010 Share Posted May 5, 2010 there is a quote button in the top right corner of each post. The forum software limits the number of quotes anyway so you do not want to many otherwise you spend ages downloading repeated material hmm meant that when you hit the quote button instead of getting into the reply it adds it as a + and then when you hit the REPLY button it uses the ammount of quotes you decided to reply to if you know what I mean? nope Quote Link to comment Share on other sites More sharing options...
marzman Posted May 5, 2010 Share Posted May 5, 2010 Nope, i dont know what you mean either? I figured out that you can quote one person and type, and then scroll up and quote another person, and it appends the new quoted section below what you've already typed... is this what you mean? Quote Link to comment Share on other sites More sharing options...
Lexx Posted May 5, 2010 Share Posted May 5, 2010 I know what you mean pal. Seen it on a number of other forums. Quote Link to comment Share on other sites More sharing options...
Chris`I Posted May 5, 2010 Share Posted May 5, 2010 there is a quote button in the top right corner of each post. The forum software limits the number of quotes anyway so you do not want to many otherwise you spend ages downloading repeated material hmm meant that when you hit the quote button instead of getting into the reply it adds it as a + and then when you hit the REPLY button it uses the ammount of quotes you decided to reply to if you know what I mean? I think I get what you mean, you want to quote multiple posts? To get around this, hit Quote on the first post, which brings you into "Post a reply" page. At the bottom of that, you get the thread again, hit quote on the other posts you want to quote and they will pop up in the reply panel Its a completely different forum software that lets you quote like you suggest, I think Invasion board or something like that, not phpBB that we use. Quote Link to comment Share on other sites More sharing options...
andlid Posted May 5, 2010 Author Share Posted May 5, 2010 there is a quote button in the top right corner of each post. The forum software limits the number of quotes anyway so you do not want to many otherwise you spend ages downloading repeated material hmm meant that when you hit the quote button instead of getting into the reply it adds it as a + and then when you hit the REPLY button it uses the ammount of quotes you decided to reply to if you know what I mean? I think I get what you mean, you want to quote multiple posts? To get around this, hit Quote on the first post, which brings you into "Post a reply" page. At the bottom of that, you get the thread again, hit quote on the other posts you want to quote and they will pop up in the reply panel Its a completely different forum software that lets you quote like you suggest, I think Invasion board or something like that, not phpBB that we use. ahaaaa thanks I'll give that a try now! I know what you mean pal. Seen it on a number of other forums. its working! there is a quote button in the top right corner of each post. The forum software limits the number of quotes anyway so you do not want to many otherwise you spend ages downloading repeated material hmm meant that when you hit the quote button instead of getting into the reply it adds it as a + and then when you hit the REPLY button it uses the ammount of quotes you decided to reply to if you know what I mean? nope Nope, i dont know what you mean either? I figured out that you can quote one person and type, and then scroll up and quote another person, and it appends the new quoted section below what you've already typed... is this what you mean? that works pretty well Quote Link to comment Share on other sites More sharing options...
andlid Posted May 5, 2010 Author Share Posted May 5, 2010 You learn something new EVERY day! Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted May 5, 2010 Share Posted May 5, 2010 You learn something new EVERY day! I knew that not Hello, Could we get a quote button + - after each post in a thread? so if you wanted to reply to a thread you could do that for all posts you want instead of manual copy or the lazy option to post more times? It would work as you quote and then when you hit reply you get all the quoted posts. A works for me too ....thanks Quote Link to comment Share on other sites More sharing options...
andlid Posted May 5, 2010 Author Share Posted May 5, 2010 You learn something new EVERY day! I knew that not Hello, Could we get a quote button + - after each post in a thread? so if you wanted to reply to a thread you could do that for all posts you want instead of manual copy or the lazy option to post more times? It would work as you quote and then when you hit reply you get all the quoted posts. A works for me too ....thanks lol did you get my PM re the alloys? Quote Link to comment Share on other sites More sharing options...
Chris`I Posted May 5, 2010 Share Posted May 5, 2010 Happy to help Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted May 5, 2010 Share Posted May 5, 2010 Andlid PM Yes I did thanks, I'll reply a little later. I'm looking into all the good info you gave me and will come back with comment. I'm waiting for info from the suppliers at the mo Cheers Quote Link to comment Share on other sites More sharing options...
Chesterfield Posted May 5, 2010 Share Posted May 5, 2010 If it helps - I didn't know it did that Does that instill you with any confidence that the mobile version of the site will work well? Quote Link to comment Share on other sites More sharing options...
andlid Posted May 5, 2010 Author Share Posted May 5, 2010 Happy to help Quote Link to comment Share on other sites More sharing options...
andlid Posted May 5, 2010 Author Share Posted May 5, 2010 If it helps - I didn't know it did that Does that instill you with any confidence that the mobile version of the site will work well? Quote Link to comment Share on other sites More sharing options...
nixy Posted May 5, 2010 Share Posted May 5, 2010 quoting is something i should do more often - i hate it when people go back and edit their posts afterwards to totally change it after i've replied - you know who you are! Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted May 5, 2010 Share Posted May 5, 2010 If it helps - I didn't know it did that Does that instill you with any confidence that the mobile version of the site will work well? have all the faith in the world quoting is something i should do more often - i hate it when people go back and edit their posts afterwards to totally change it after i've replied - you know who you are! can't be me Happy to help thanks chris i never new that either like you say, learn something new every day. should make life easier than when i used to open the same page on 5 tabs to copy and paste quotes from different people Quote Link to comment Share on other sites More sharing options...
nixy Posted May 5, 2010 Share Posted May 5, 2010 I think you should only be able to go back and edit your post if you do it within a couple of mins if you notice a spelling mistake or something but changing it after someone's replied isn't fair - you should have to ask a mod to do it (they could do with a few more jobs!) Quote Link to comment Share on other sites More sharing options...
Chris`I Posted May 5, 2010 Share Posted May 5, 2010 you should have to ask a mod to do it (they could do with a few more jobs!) Thanks We can lock a post so you cant edit it again, so you better place nice or the post fairy might be along and update and lock it Quote Link to comment Share on other sites More sharing options...
andlid Posted May 5, 2010 Author Share Posted May 5, 2010 create your own thread! Quote Link to comment Share on other sites More sharing options...
nixy Posted May 5, 2010 Share Posted May 5, 2010 you should have to ask a mod to do it (they could do with a few more jobs!) Thanks We can lock a post so you cant edit it again, so you better place nice or the post fairy might be along and update and lock it do you know where i'm coming from though? It's not that important usually - I know on the forum i moderate on (absently mostly) we have a trash can section where all the delted stuff can be read but I don't think we can look at stuff prior to editing to see what it said before if someone just goes in and alters the context of it all. Quote Link to comment Share on other sites More sharing options...
Chris`I Posted May 5, 2010 Share Posted May 5, 2010 Yeah I know what you mean Nix, it is a PITA at times. Not a lot we can do about it though, just have to hope members dont abuse it. Quote Link to comment Share on other sites More sharing options...
andlid Posted May 5, 2010 Author Share Posted May 5, 2010 Surely this would all be logged somewhere? Yeah I know what you mean Nix, it is a PITA at times. Not a lot we can do about it though, just have to hope members dont abuse it. Quote Link to comment Share on other sites More sharing options...
Stew Posted May 5, 2010 Share Posted May 5, 2010 I hate when people ask a question,. get answers then edit the question. Bugs the hell out of me. Doesn't help other members doing searches either! Quote Link to comment Share on other sites More sharing options...
