captint Posted August 29, 2006 Share Posted August 29, 2006 I have been on MY350Z.com and they are talking about spacers and MREVs, what are they? I take it they don't mean wheel spacers? Quote Link to comment Share on other sites More sharing options...
Jacko Posted August 29, 2006 Share Posted August 29, 2006 I have been on MY350Z.com and they are talking about spacers and MREVs, what are they? I take it they don't mean wheel spacers? Would have thought that spacers were wheel spacers..... not sure on MREVs? Isn't there a glossary on that site....... Quote Link to comment Share on other sites More sharing options...
Removed Posted August 29, 2006 Share Posted August 29, 2006 spacer in this case are PLENUM spacers MREV's are spacer types sold by motordyne engineering. (I think they are for the 300ps engines? ) instead of buying a brand new plenum to increase air capacity, you stick a spacer in between with the same results. That's what i'll be doing soon too. Quote Link to comment Share on other sites More sharing options...
captint Posted August 29, 2006 Author Share Posted August 29, 2006 Cheers for that, so If I already have a Kinetix Plenium do I need to do this too? Quote Link to comment Share on other sites More sharing options...
lomoto Posted August 29, 2006 Share Posted August 29, 2006 spacer in this case are PLENUM spacers MREV's are spacer types sold by motordyne engineering. (I think they are for the 300ps engines? ) instead of buying a brand new plenum to increase air capacity, you stick a spacer in between with the same results. That's what i'll be doing soon too. Do you have to do without strut bar if a spacer is fitted? Quote Link to comment Share on other sites More sharing options...
Rob_Quads Posted August 29, 2006 Share Posted August 29, 2006 spacer in this case are PLENUM spacers MREV's are spacer types sold by motordyne engineering. (I think they are for the 300ps engines? ) instead of buying a brand new plenum to increase air capacity, you stick a spacer in between with the same results. That's what i'll be doing soon too. What do you gain from having an increased air capacity as your still limited by the same size throttle body Quote Link to comment Share on other sites More sharing options...
captint Posted August 29, 2006 Author Share Posted August 29, 2006 there is very little room between my Plenium and Strut bar and I do recall a previous poste of horrible vibes coming from the two when they touch Quote Link to comment Share on other sites More sharing options...
Removed Posted August 29, 2006 Share Posted August 29, 2006 spacer in this case are PLENUM spacers MREV's are spacer types sold by motordyne engineering. (I think they are for the 300ps engines? ) instead of buying a brand new plenum to increase air capacity, you stick a spacer in between with the same results. That's what i'll be doing soon too. Do you have to do without strut bar if a spacer is fitted? there's 2 types, the 8mm one (they call it 5/16" iirc) keeps the strut bar, and the bigger one really doesn't give extra hp. Quote Link to comment Share on other sites More sharing options...
Removed Posted August 29, 2006 Share Posted August 29, 2006 Cheers for that, so If I already have a Kinetix Plenium do I need to do this too? nope Quote Link to comment Share on other sites More sharing options...
Removed Posted August 29, 2006 Share Posted August 29, 2006 spacer in this case are PLENUM spacers MREV's are spacer types sold by motordyne engineering. (I think they are for the 300ps engines? ) instead of buying a brand new plenum to increase air capacity, you stick a spacer in between with the same results. That's what i'll be doing soon too. What do you gain from having an increased air capacity as your still limited by the same size throttle body not too sure of the intrinsic mechanics of it but it's been proven over and over again that the plenum or the spacer are about the only NA mod that gives constant gains especially midrange. The first 2 cylinders are starved for air as opposed to the other 4 (look on APS's website for a picture of the 2 plenums to compare). I guess a more even airflow to all cylinders gives the gains found Quote Link to comment Share on other sites More sharing options...
Removed Posted August 29, 2006 Share Posted August 29, 2006 there is very little room between my Plenium and Strut bar and I do recall a previous poste of horrible vibes coming from the two when they touch the OEM strut bar is adjustable ... Quote Link to comment Share on other sites More sharing options...
