B16REE Posted May 3, 2010 Share Posted May 3, 2010 hi, Ive got a JDM zed but have an ugly bolt on foglight, is there anything i can do to make it part of the cluster on the RHS? cheers Quote Link to comment Share on other sites More sharing options...
marzman Posted May 3, 2010 Share Posted May 3, 2010 Take a look at these pictures mate... should be easy enough to do yourself with a dremmel and and afternoon: If your fog existing fog light is the right size, you can use that, if not i think they're only a tenner from halfords... Quote Link to comment Share on other sites More sharing options...
type g Posted May 3, 2010 Share Posted May 3, 2010 Hey B16REE, If you want a dremmel-free alternative see below: Firstly this is the light i am working with: you will need to chop the wires on the rear of the light after the connector (see below): following that, change the light (shown disconnected) to a red bulb and connect the wires from the bulb to the ones powering your existing foglight. Failing that you could buy a UK cluster with bulbs (from Nissan for approx £60) and do exactly the same! (which is what i've done) Quote Link to comment Share on other sites More sharing options...
B16REE Posted May 3, 2010 Author Share Posted May 3, 2010 Thanks, they seem ok, but TBH i was looking for a bolt on job as ive already got an FTO Drag car which im always working on, so wanted to keep the zed as a non modder! but the second option does seem less hassle, prob get hold of a uk cluster. cheers Quote Link to comment Share on other sites More sharing options...
mrCD Posted July 19, 2010 Share Posted July 19, 2010 I've painted my bulb red and added a cable to light it whenever it's needed. Three hour work tops. Quote Link to comment Share on other sites More sharing options...
Husky Posted July 19, 2010 Share Posted July 19, 2010 if you already have the wiring for the fog, just take that wiring over to the cluster, splice it in place of the reverse light and put a red bulb in. EDIT: exactly has already been stated above Quote Link to comment Share on other sites More sharing options...
