Cookbots Vortech S/C Build
Cookbot
Well as every one else is doing it, I thought I'd jump on the band wagon. The first part to fit was the oil cooler and that's now done although it proved to be more awkward than I expected it to be. Then I realised the company I got the oil cooler from had just sent me a sandwich plate and not a thermostat one, so guess what I'll be doing next weekend! :dry:
  • Replies 61
  • Created
  • Last Reply
Top Posters In This Topic
Never got any pics after, although I'll be fitting a radiator next so will get some then. Did have to drain the oil, which is a bummer as I will have to drain it again to fit the thermostat one. Why would I need to remove it for the SC? All that goes down there is the intercooler and that should fit if my measurements are good.
what I mean is the following;
on the top and bottom of the oilcooler there are 2 holes per mounting, you need to provide support between these holes, we use a pipe that fit between the holes (top and bottom) and use a piece of 6mm studding to go through both top/bottom mounting holes and bolted tight this is to stop the care being twisted or vibrated.
I will take a picture next week if I find time.
Mark
  • 1 month later...
Managed to get around to changing that sandwich plate and fitted some threaded rod. Is this what you meant by supporting it?
Got 3 weeks of work now so need to get around to ordering the bulk of the stuff now. Got the spark plugs and a catch can on the way already.
  • 4 months later...
