Rear bumper holes ???
M9O OEY
:thumbs: Thanks I think its probably not the correct size i will have to get a better sized plate, does anyone on here sell the correct sized plates for JDMs? I Find it strange why there are two holes either side of the plate tho, someone must know.
It looks a little like a squashed 'T' if you remove the plate. Its strange but as you say I am sure it has a purpose. Generally anywhere that does plates can do you a custom sized one. I actually got my first one from Halfrauds after giving them the size. Just measure what you want and ask a plate maker to make you one up.
got mine from demonplates
jdm standard size but you can still just see the holes at the top on either side, only just though
Yeah thats the same as mine you can only see it if you look closely :thumbdown: The hole for the plate to fit in seems to taper so i guess the plate would need to be trimmed down to hide the holes :thumbs:
