Ian Posted April 29, 2010 Share Posted April 29, 2010 To install the ARC, remove this pipe Then run the shortest supplied hose from the left most hose to the left side of the catch can & use the supplied cap to block off the other port. Then remove your intake pipe & you will notice a hose that runs from the underside of the intake pipe around to the back of the engine block, remove this hose. Connect the longest supplied hose to the back of the engine block & connect to the remaining port on the left of the ARC can. Fit the remaining supplied hose into the intake pipe port & connect to the right side of the ARC can Finished This guide can be used for any catch can with 3 ports Quote Link to comment Share on other sites More sharing options...
andlid Posted October 30, 2011 Share Posted October 30, 2011 sort out that last photo... need to compare the one install I got. Quote Link to comment Share on other sites More sharing options...
