cfoster Posted April 29, 2010 Share Posted April 29, 2010 Quite fancy installing some LED lights into the door reflectors and also some leds pointing down as puddle lights. Has anyone done this and if so where did you buy the lights from? Chris Quote Link to comment Share on other sites More sharing options...
ikarus Posted April 29, 2010 Share Posted April 29, 2010 Speak to Husky, I think he knows about lighting.. Quote Link to comment Share on other sites More sharing options...
Husky Posted April 29, 2010 Share Posted April 29, 2010 im working on this for a members car just now. it shouldn't be too expensive i just need to find a spare moment to finish them. shouldnt be long now though Quote Link to comment Share on other sites More sharing options...
cfoster Posted April 30, 2010 Author Share Posted April 30, 2010 I've found this firm here that do LED lighting and seem quite cheap, reckon they may tuck in behind the door reflectors and stick underneath the doors as puddles. Presume i'd just wiring them in series and take a feed from one of the interior lights or the door switch? http://www.litewave.co.uk/lighting_gizmos.asp Chris Quote Link to comment Share on other sites More sharing options...
Wez21 Posted May 6, 2010 Share Posted May 6, 2010 Hi Chris, I have done exactly this! Cheapest and best looking way imo is too just buy some white leds and resistors from ebay, make a small panel, drill holes, glue them in, then glue the panel in behind the reflector! I have 16 behind one reflector and it looks spot on! Completely OEM look! If you wanted you could even do them in the shape of a Z!! I put 4 along the bottom of the door card too, these had the shrouds on so they only direct the light down! Very handy in the dark for seeing what you step out into! I just ran the wire through the door harness and tapped into the room lamp! While I was on I put some orange leds in the footwell for when the door is open too!! I think all in only cost a few pounds!! Quote Link to comment Share on other sites More sharing options...
narcotix Posted May 11, 2010 Share Posted May 11, 2010 Hi Chris, I have done exactly this! Cheapest and best looking way imo is too just buy some white leds and resistors from ebay, make a small panel, drill holes, glue them in, then glue the panel in behind the reflector! I have 16 behind one reflector and it looks spot on! Completely OEM look! If you wanted you could even do them in the shape of a Z!! I put 4 along the bottom of the door card too, these had the shrouds on so they only direct the light down! Very handy in the dark for seeing what you step out into! I just ran the wire through the door harness and tapped into the room lamp! While I was on I put some orange leds in the footwell for when the door is open too!! I think all in only cost a few pounds!! Quote Link to comment Share on other sites More sharing options...
Wez21 Posted May 13, 2010 Share Posted May 13, 2010 Haha, ill try and get some up tomorrow. Do most people use photobucket? not put any on here before!! Ill try and get some both day and night shots! Quote Link to comment Share on other sites More sharing options...
Husky Posted May 13, 2010 Share Posted May 13, 2010 Haha, ill try and get some up tomorrow. Do most people use photobucket? not put any on here before!! Ill try and get some both day and night shots! yeah photobucket you can upload direct to here aswell Quote Link to comment Share on other sites More sharing options...
Wez21 Posted May 24, 2010 Share Posted May 24, 2010 Well here goes! Hope you can see them, did not realise how bright the door reflector is until I tried to capture it on the camera! Quote Link to comment Share on other sites More sharing options...
UNABASHED Posted May 24, 2010 Share Posted May 24, 2010 Quote Link to comment Share on other sites More sharing options...
robadob Posted May 25, 2010 Share Posted May 25, 2010 That looks pretty smart - is the light cast by the under-door LEDs actually a bit wider than it looks in the photo? Or is it really just a spot? I know cameras aren't great at high contrast photos... Quote Link to comment Share on other sites More sharing options...
Wez21 Posted May 25, 2010 Share Posted May 25, 2010 Yeah, its quite a big area covered. It is brighter right below where the LED's are but is spread further out. Your right it was a pain to get a decent photo. If it helps I used some black LED holders for the white ones so that you can hardly see them from the side. I suppose you could go wild and put quite a few more along the door but I thought that ould be like a runway, and 4 is very bright anyway! Quote Link to comment Share on other sites More sharing options...
