biggmacp Posted April 28, 2010 Share Posted April 28, 2010 Hi all brake lights have come up on my dash , so checked fluid was fine checked pads about half worn , disks looked little bit worn so maybe front right even both sides of disc, front left out of disc looks good but inside was thinner??? Also when braking getting a grinding feeling through pedal and slight pull to left but only sometimes happens ??? So any help please car is 05 with brembo have full set off yelowstuff pads in box ready to cheers Greg Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted April 28, 2010 Share Posted April 28, 2010 Hi all brake lights have come up on my dash , so checked fluid was fine checked pads about half worn , disks looked little bit worn so maybe front right even both sides of disc, front left out of disc looks good but inside was thinner??? Also when braking getting a grinding feeling through pedal and slight pull to left but only sometimes happens ??? So any help please car is 05 with brembo have full set off yelowstuff pads in box ready to cheers Greg Best to get all four wheels off for a closer inspection, Sounds like one of the pads that you can't see may be down to the metal. Quote Link to comment Share on other sites More sharing options...
