H5 Posted August 28, 2006 Share Posted August 28, 2006 It comes on at start up, but then flashes. Manual says it could either: - 1) Stay on all the time 2) Flash 3) Never come on All mean there's something needing checking - anyone else had it flashing? Ming, hold up on the detailing challenge, I might be cleaning talcum powder and cornflour off my interior soon!! Quote Link to comment Share on other sites More sharing options...
Liam's Z Posted August 28, 2006 Share Posted August 28, 2006 H5 I'm not clear in what your saying!!!! Do you mean when you start the car and the airbag and everything else goes through it's self checking process that the air bag light remains on and continues to flash??? If so this has happened 2 me I'll see if I can find the thread for clearing it..... Really should go back 2 the dealers..... Quote Link to comment Share on other sites More sharing options...
Liam's Z Posted August 28, 2006 Share Posted August 28, 2006 In the event of having a flashing Airbag warning light (but with no fault with the system), then follow the following procedure: This procedure will CLEAR the AirBag light ONLY if you do not have problems with the airbags on your 350Z. 1. Turn ignition switch from OFF to ON. 2. Air Bag warning lamp is on for 7 seconds and turns off, then turn ignition switch OFF within 1 second after the lamp turn off. 3. After ignition switch is turned OFF, wait for more than 3 seconds. 4. Repeat steps 1 to 3 twice. (Perform 3 times in total.) 5. Turn Ignition switch ON. 6. The SRS lamp has been reset it. In the event that this does not work, then may be indicative of an actual fault and further investigation should be sought. H5 if comes back, please have it checked out properly.... Btw it took me a couple of goes,,, think I didn't get the timing right first time Quote Link to comment Share on other sites More sharing options...
H5 Posted August 28, 2006 Author Share Posted August 28, 2006 Cheers Liam! Will go try. No doubt will get it looked at if it doesn't reset. Just wondered if flashing meant something specific. Quote Link to comment Share on other sites More sharing options...
H5 Posted August 28, 2006 Author Share Posted August 28, 2006 Liam you legend! Took a couple of goes, but got it done. Reset and all good. Cheers matey! Any ideas why it does this?? Quote Link to comment Share on other sites More sharing options...
M13KYF Posted August 28, 2006 Share Posted August 28, 2006 low voltage trigger follwed by poor earth and high hummidty and a y in the day and a curry the night before. One of those things Quote Link to comment Share on other sites More sharing options...
H5 Posted August 28, 2006 Author Share Posted August 28, 2006 You have no idea how accurate that is Mike!! Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted August 28, 2006 Share Posted August 28, 2006 low voltage trigger follwed by poor earth and high hummidty and a y in the day and a curry the night before. One of those things Mike, You have put up a FAQ but it is a repeat of one Jacko did when Liam reset his - based on information supplied by yours truly Quote Link to comment Share on other sites More sharing options...
M13KYF Posted August 28, 2006 Share Posted August 28, 2006 for once i'm too efficent. I checked but didn't see it. I shall remove it now. Cheers Dorian Quote Link to comment Share on other sites More sharing options...
Liam's Z Posted August 29, 2006 Share Posted August 29, 2006 low voltage trigger follwed by poor earth and high hummidty and a y in the day and a curry the night before. One of those things Mike, You have put up a FAQ but it is a repeat of one Jacko did when Liam reset his - based on information supplied by yours truly H5 don't thank me thank Dorian (who's he gonna thank) He pulled me out the @*!# with it Like he said to me it's a quick fix!!! If it returns get it checked out properly Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted August 29, 2006 Share Posted August 29, 2006 If I could remember the guy on my350Z who posted it, I would defer the credit to him, no probs I did have to search quite a bit to find it, so 34.578% of the credit is due to me Quote Link to comment Share on other sites More sharing options...
H5 Posted August 29, 2006 Author Share Posted August 29, 2006 I have to take some of that - takes a while to get that timing right!!! Quote Link to comment Share on other sites More sharing options...
