Buddy Club EXHAUST + High flow Kinetix cats SOLD
lotuscc
Pair of High flow Kinetix catalytic converters that will pass MOT test.
They are heat shielded – very important!
Fits all 350Z 2002 – 2006 (including rev-up model)
Constructed with stainless tubing and 3/8" stainless flanges. Fully TIG welded and true mandrel bends used throughout. About half the weight of OEM. These converters will bolt up to any header (factory or aftermarket) and any exhaust (factory or aftermarket). These pipes also retain the factory Oxygen sensor location and WILL NOT THROW A CHECK ENGINE LIGHT!!.
Expect great performance gains from these converters as they have dyno'd between 6-8 hp at the wheels on factory 350Z's. They only add a slightly more aggressive exhaust note and do not have the pesky "raspiness" between 3-4k rpm that is seen with straight through test pipes.
Used for less than 10,000 miles. Will last approx 100,000 miles.
£250 plus £25 postage.
Details of exhaust: Buddy Club SPEC III PRO EXHAUST (one of the lightest stainless steel 350Z systems that you can buy). Independent dyno test shows 15hp power gain. Fitted with removable rear box baffles. Lovely sound and not boomy or intrusive on longer journeys. See review article of system:
http://www.importtuner.com/tech/powerpa ... haust.html
If you want to hear a sound clip of exhaust then let me know.
Used for around 12,000 miles. Stainless steel so will last approx 100,000 miles.
£350 plus £50 postage
