first problem
dr bru
im assuming the place to refill is the name as the wiper fluid as these seem to be working fine ie hasnt run out of water
correct
also don't bother testing them with the button next to the VDC. I test them like this: switch the lights on then use the windscreen wipers. They should work simultaneously
correct
Val is correct they should work simultaneously but only on initial go, must be a timing sequence ;)
BTW light washer reservoir runs out before window reservoir.... Reason being, what's the point of light if you can't see out the bloody windows ;)
