Wookiee22 Posted April 24, 2010 Share Posted April 24, 2010 Having done a bit of reading up I've decided to take the plunge and get a DA polisher as above. My question is which kit to go for? Obviously I need pads and compounds that are not too aggressive due to the soft, thin paint on the zed. Was leaning towards the Sonus SFX stuff, anyone got any thoughts? Quote Link to comment Share on other sites More sharing options...
Stew Posted April 24, 2010 Share Posted April 24, 2010 Had a look on the i4detailing site. The Sonus kit is for soft paint so is most suited to the Zed. I've used sonus pads but never sonus polish so I can't comment on them. The pads are alright though! Quote Link to comment Share on other sites More sharing options...
Wookiee22 Posted April 24, 2010 Author Share Posted April 24, 2010 Thanks Stew! Is there anything else you reckon I should look at at the same time? I currently use a bit of Megs polish and then Collinite wax, both by hand obviously. Is there much point in looking at machine - applied sealents etc? Quote Link to comment Share on other sites More sharing options...
Stew Posted April 24, 2010 Share Posted April 24, 2010 Thanks Stew! Is there anything else you reckon I should look at at the same time? I currently use a bit of Megs polish and then Collinite wax, both by hand obviously. Is there much point in looking at machine - applied sealents etc? Depends what finish you want to achieve to be honest. Myself and Jason did this - viewtopic.php?f=22&t=35275 We used Megs 205 then some poorboys blackhole glaze, blackfire sealant and topped it off with Dodo Purple Haze (I think...) If you are new to machining I'd recommend some poorboys blackhole glaze (or white diamond - I don't know which on GM...) I put it on via machine, as it helps fill scratches and RDS that are left behind after polishing. It gives a real deep shine. Jason couldn't believe the difference after the glaze was applied. My favourite products is STILL Blackfire sealant. I've been using it for 2 years plus and I still love it! Quote Link to comment Share on other sites More sharing options...
