showtime1 Posted April 23, 2010 Share Posted April 23, 2010 BEEN OUT TODAY FOR A BLAST NOTICED THAT WHEN IM IN A GEAR HIT THE THROTTLE QUITE HARD THE REVS JUMP UP REALLY FAST AND THEN DROP IS THIS NORMAL FIRST MANUAL IVE HAD FOR 4 YRS COULD IT BE THE CLUTCH IVE TRIED TO DO A RESET BUT I CANT GET IT TO WORK CANT GET THE CEL LIGHT FLASHING INFACT DONT KNOW WHAT THE CEL LIGHT IS IVE NOT GOT ONE ON MINE Quote Link to comment Share on other sites More sharing options...
MacW Posted April 23, 2010 Share Posted April 23, 2010 Sounds like the clutch might be slipping. Although tbh it's tough to read when you're shouting and not taking a breath Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted April 23, 2010 Share Posted April 23, 2010 i'm confused, is the CEL light flashing, or are you trying to make it flash? if it is flashing, don't drive it the engine is proper bolloxed, if your referring to the Traction control and stability control and you want to make the lights flash, turn off traction control. to be honest when pulling away, you shouldnt have any flashy lights apart from the TCS and ESP if you have to much power and your spinning the wheels. when you stab the throttle hard, are you keeping your foot on it or is it just a jab, if the revs are dropping it might be because you've taken your foot off the pedal. also remember the car throttle is drive by wire so no throttle cable, the car will self adjust to what it needs etc. but admitedly what you've written makes no sense what so ever. Quote Link to comment Share on other sites More sharing options...
Ekona Posted April 23, 2010 Share Posted April 23, 2010 I HAS MAEJOR TROOBLEZ UNNERSTANDING WOT HE HAS WRITTEN LIEK ;) Quote Link to comment Share on other sites More sharing options...
andlid Posted April 23, 2010 Share Posted April 23, 2010 after some reading you seem to havea problem with the pedals timing resulting in the engine light not starting to flash after 12 seconds? (the easy method) It does sound like you got a slipping clutch. Can you try and put the car into a higher type gear and go uphill somewhere and see if the car starts slipping on the clutch? Search for 'easy ecu reset' and you'll find following that will be 100% better and easier then the normal one.! Quote Link to comment Share on other sites More sharing options...
showtime1 Posted April 23, 2010 Author Share Posted April 23, 2010 after some reading you seem to havea problem with the pedals timing resulting in the engine light not starting to flash after 12 seconds? (the easy method) It does sound like you got a slipping clutch. Can you try and put the car into a higher type gear and go uphill somewhere and see if the car starts slipping on the clutch? Search for 'easy ecu reset' and you'll find following that will be 100% better and easier then the normal one.! cheers mate ive done it, it was ticking over at 900rpm after i cleaned the tb, but ive reset everything and its tickover is 600 all sweet. it might be the clutch slipping a tad, seems better now though are clutches expensive? thx for the help Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted April 23, 2010 Share Posted April 23, 2010 Certainly sounds like your clutch is slipping by the description that you have given. I have OEM Exedy Clutch Kits in stock at only £260.00 and good to go same/next day. viewtopic.php?f=38&t=27436 Drop me a pm if I can help you further. Cheers, Alex. Quote Link to comment Share on other sites More sharing options...
showtime1 Posted April 23, 2010 Author Share Posted April 23, 2010 Certainly sounds like your clutch is slipping by the description that you have given. I have OEM Exedy Clutch Kits in stock at only £260.00 and good to go same/next day. viewtopic.php?f=38&t=27436 Drop me a pm if I can help you further. Cheers, Alex. cheers i will how much to get fitted Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted April 23, 2010 Share Posted April 23, 2010 Certainly sounds like your clutch is slipping by the description that you have given. I have OEM Exedy Clutch Kits in stock at only £260.00 and good to go same/next day. viewtopic.php?f=38&t=27436 Drop me a pm if I can help you further. Cheers, Alex. cheers i will how much to get fitted Around £200.00 depending on your location. Quote Link to comment Share on other sites More sharing options...
showtime1 Posted April 23, 2010 Author Share Posted April 23, 2010 east mids leics Quote Link to comment Share on other sites More sharing options...
BladesGrant Posted April 23, 2010 Share Posted April 23, 2010 east mids leics Speak to CS for fitting a trader on here. He will sort you out. Quote Link to comment Share on other sites More sharing options...
