hi a few questions for newbie
hi everyone just bought a 350z comming from an audi tt 3.2 got it home tonight oil looks very low is it meant to show with just a bit on the bottom very fidley getting it out where the best place for remaps and what sort of gains can i expect cheers
Check the level when the oil is cold and you are on level ground. You might have to 'dip' several times to get a relaible reading. Also - what is the oild pressure guage reading at tickover and at 60mph in 6th gear? If the guage seems a bit erractic that is a sign of low oil as the pump picks up what is there and in turn triggers the guage sensor.
If stil in doubt go back to the garage and insist on an oil change ;)
how do you remove the power limiter cheers
Remap gains depend on the other mods you have fitted, between 10 and 30BHP seems to be the norm. More important might be the removal of the power limiter in lower gears and a smoother a/f mixture plot
