Bundus Posted April 20, 2010 Share Posted April 20, 2010 Hey guys I have my Alpine IVA W200Ri (touch screen double din dvd player) fitted to my zed and I wired it up with the PAC Audio interface which meant I had to cut the ISO connector off the Alpine unit and splice all the wires into the PAC box. Im now using all aftermarket equipment powered by amps running off the RCA's so there is no need for the PAC box so Im removing it. My question is what type of ISO lead will I need to fit my Alpine unit directly to the zed? If I bought a replacement ISO lead for the Alpine would that plug and play with the Zed or will I need another adaptor? Cheers! Quote Link to comment Share on other sites More sharing options...
yokomo Posted April 20, 2010 Share Posted April 20, 2010 im assuming you had bose , and didnt use the pre outs ? if your fully amped now then all you rally take from the Z is the power , dimmer signal from the light and remote . if its all working id leave it unless your trying to take the amps out and use the bose amps OOrr im barking up the wrong tree. Quote Link to comment Share on other sites More sharing options...
Rob_Quads Posted April 20, 2010 Share Posted April 20, 2010 If you are using all non-BOSE setup for the audio then you just need the bog standard Nissan Micra loom adapter to give you power etc to the Alpine ISO loom Here you go - http://www.sextonsdirect.co.uk/ict/p~20-134.html?cat=0 Quote Link to comment Share on other sites More sharing options...
Bundus Posted April 20, 2010 Author Share Posted April 20, 2010 Thanks guys Im basically taking out the PAC audio as it takes up too much space behind the dash (ive never got my centre console back on properly with this in place along with 3 sets of RCA's lol). I took my centre console out to wrap it and this seems like a good time to clear out un wanted junk. Thanks Rob Quads - thats what I need. I think I'll also need to replace my Alpine ISO lead then as its all been cut up to splice to the PAC. Although Im guessing I could splice my Alpine ISO directly into the Micra ISO? So basically be the same set up I have now but splicing directly to the Micra ISO instead of the PAC audio box! Sound about right? Quote Link to comment Share on other sites More sharing options...
