Corrado Posted April 18, 2010 Share Posted April 18, 2010 Hi, It's time for a spark plug change, and I've been impressed with what I've been reading about the added performance from DENSO Iridium plugs. My car is a completely standard 276bhp model, which has never had a plug change before. My mechanic is quite 'old school' and was in the place that NGK were well proved long-term, and I should stick with them. Has anyone been running DENSO's for 4/5 years? Given that the plugs take a bit of messing about to access on the 350Z, I wanted to do the job once and be done for the next 5 years. Any feed-back would be appreciated. Thanks! Quote Link to comment Share on other sites More sharing options...
Ekona Posted April 18, 2010 Share Posted April 18, 2010 Unless you're running FI then messing about with the plugs will only ever produce a really minor difference either way. Get whichever is the cheapest IMHO, even if you gain 1bhp is it worth the extra expense? Crap new plugs will make the difference over brilliant older ones anyway. Quote Link to comment Share on other sites More sharing options...
was8v Posted April 18, 2010 Share Posted April 18, 2010 Denso Iridium worked out cheaper than NGK platinum for me. Sign up with opieoils.co.uk as a member (to get reduced prices) and use the code APRILFREESHIP to get free delivery. A full set of 6 denso iridium is about £42 delivered. Even cheaper is the NGK copper alternative at around £25, but then you have to replace them after around 15k and some say they don't produce as good a spark leading to a very slight reduction in fuel economy and performance. IIRC iridium are changed after 40-50k miles. Quote Link to comment Share on other sites More sharing options...
Corrado Posted April 24, 2010 Author Share Posted April 24, 2010 Do you know is NGK offer a Iridium version, there's a slightly confusing threat on here which implies they might, by I can't find it listed assuming you'd change the P of PLFR5A-11 to an 'I' so been asking for NGK : ILFR5A-11 Quote Link to comment Share on other sites More sharing options...
Ian Posted April 24, 2010 Share Posted April 24, 2010 Do you know is NGK offer a Iridium version, there's a slightly confusing threat on here which implies they might, by I can't find it listed assuming you'd change the P of PLFR5A-11 to an 'I' so been asking for NGK : ILFR5A-11 yeah they do, i'm running a set Quote Link to comment Share on other sites More sharing options...
Corrado Posted April 24, 2010 Author Share Posted April 24, 2010 Great, thanks. Don't suppose you have a reference code for them? Quote Link to comment Share on other sites More sharing options...
gunmetalzgt Posted April 24, 2010 Share Posted April 24, 2010 Pm CS, he has the NGK ones at a fantastic price Quote Link to comment Share on other sites More sharing options...
Corrado Posted April 24, 2010 Author Share Posted April 24, 2010 CS? Quote Link to comment Share on other sites More sharing options...
Corrado Posted April 24, 2010 Author Share Posted April 24, 2010 Ah, got it, thanks! Dropped a PM! Quote Link to comment Share on other sites More sharing options...
Ian Posted April 24, 2010 Share Posted April 24, 2010 Great, thanks. Don't suppose you have a reference code for them? LFR5AIX-11 Quote Link to comment Share on other sites More sharing options...
Corrado Posted April 24, 2010 Author Share Posted April 24, 2010 Brilliant! Thank you! Quote Link to comment Share on other sites More sharing options...
MattG Posted April 28, 2010 Share Posted April 28, 2010 It's worth mentioning that Denso do a "Tough" version of their Iridium plug that lasts even longer than normal iridiums. Opie sell these too but they are a little more expensive than normal Iridiums. Sounds like a good option for you if you want the plugs to last as long as possible. Quote Link to comment Share on other sites More sharing options...
