Husky Posted June 2, 2010 Share Posted June 2, 2010 Found out another issue if you let the sd card get full (which I did) it does not have enough space to sort out the index file properly and thus corrupting the AVI file. Can't copy it off the card and can't repair it onto the card either (since its full) Currently trying to fix it with VLC which works to pla It is not OK to format the micro SD card in the 808 camera because it will "shrink" the device with each new partitioning. Summary: The implementation of the card reader functionality of the 808 mini camera is defective. If the card is fully written one needs to unplug the card from the 808 camera and read it with a different (non-buggy) card-reader. The 808 camera reports the device size wrongly. It somehow calculates the device size (cylinders/heads/sectors) of the SD card from the partition size. This approach is wrong. It always reports too less bytes. This leads to a problem with operating system. There can be files written by the 808 camera that are not accessible once you use it as USB-storage. I have had the problem, that always I couldn't read the last video that was recorded. I investigated and I saw that the operating system complained about the partition being larger than the device size. So I repartitioned my SD card inside the 808 camera. At the next disconnect/reconnect cycle the operation system again complained, showing now even smaller device size for the SD card. Also unplug the card from the 808 camera didn't help. When I connected the SD card with a different reader the original device size was reported. Quote Link to comment Share on other sites More sharing options...
andlid Posted June 5, 2010 Share Posted June 5, 2010 Found out another issue if you let the sd card get full (which I did) it does not have enough space to sort out the index file properly and thus corrupting the AVI file. Can't copy it off the card and can't repair it onto the card either (since its full) Currently trying to fix it with VLC which works to pla It is not OK to format the micro SD card in the 808 camera because it will "shrink" the device with each new partitioning. Summary: The implementation of the card reader functionality of the 808 mini camera is defective. If the card is fully written one needs to unplug the card from the 808 camera and read it with a different (non-buggy) card-reader. The 808 camera reports the device size wrongly. It somehow calculates the device size (cylinders/heads/sectors) of the SD card from the partition size. This approach is wrong. It always reports too less bytes. This leads to a problem with operating system. There can be files written by the 808 camera that are not accessible once you use it as USB-storage. I have had the problem, that always I couldn't read the last video that was recorded. I investigated and I saw that the operating system complained about the partition being larger than the device size. So I repartitioned my SD card inside the 808 camera. At the next disconnect/reconnect cycle the operation system again complained, showing now even smaller device size for the SD card. Also unplug the card from the 808 camera didn't help. When I connected the SD card with a different reader the original device size was reported. Latest video: Was going to the shop to get some milk One camera on the roof and the second on the PIP is mounted under the reg plate used the sound of that one, not matched 100% I think but needed to get a video up fastish Will work a bit more with the quality too since youtube wrecks it Quote Link to comment Share on other sites More sharing options...
Stew Posted June 5, 2010 Share Posted June 5, 2010 I'd adjust the sound levels. It makes the vid look like a 1.2 Corsa with a dustbin exhaust. FAR too much noise for the percieved speed in the vid. In my opinion of course. Quote Link to comment Share on other sites More sharing options...
andlid Posted June 5, 2010 Share Posted June 5, 2010 I'd adjust the sound levels. It makes the vid look like a 1.2 Corsa with a dustbin exhaust. FAR too much noise for the percieved speed in the vid. In my opinion of course. it does look slow from the front... not sure why really wasnt going that slow Quote Link to comment Share on other sites More sharing options...
Stew Posted June 5, 2010 Share Posted June 5, 2010 I'd adjust the sound levels. It makes the vid look like a 1.2 Corsa with a dustbin exhaust. FAR too much noise for the percieved speed in the vid. In my opinion of course. it does look slow from the front... not sure why really wasnt going that slow That's why I said perceived. Lower mounts make for faster looking vids. Quote Link to comment Share on other sites More sharing options...
Husky Posted June 5, 2010 Share Posted June 5, 2010 just removed my backbox to swap it... dont think i can resist taking a wee tiny run with no backbox will record with our little cameras as a test of sound recording ability Quote Link to comment Share on other sites More sharing options...
andlid Posted June 5, 2010 Share Posted June 5, 2010 I'd adjust the sound levels. It makes the vid look like a 1.2 Corsa with a dustbin exhaust. FAR too much noise for the percieved speed in the vid. In my opinion of course. it does look slow from the front... not sure why really wasnt going that slow That's why I said perceived. Lower mounts make for faster looking vids. I see thats why it looks faster from the rear.. to be honest I love the sound and so did everyone esle down at the track day I sit like alittle kid looking through the 3hours odd of vids Quote Link to comment Share on other sites More sharing options...
andlid Posted June 5, 2010 Share Posted June 5, 2010 just removed my backbox to swap it... dont think i can resist taking a wee tiny run with no backbox will record with our little cameras as a test of sound recording ability Quote Link to comment Share on other sites More sharing options...
Husky Posted June 5, 2010 Share Posted June 5, 2010 oh that was too good, vid up in a min, to keep on topic... the sound recording is scaled in volume, so if something loud comes along it automatically turns the volume down, frustrating on the road of course as the volume is so variable. i still think it'd be best to record the sound on a cheap dedicated device instead and splice back in at the end. Quote Link to comment Share on other sites More sharing options...
andlid Posted June 5, 2010 Share Posted June 5, 2010 oh that was too good, vid up in a min, to keep on topic... the sound recording is scaled in volume, so if something loud comes along it automatically turns the volume down, frustrating on the road of course as the volume is so variable. i still think it'd be best to record the sound on a cheap dedicated device instead and splice back in at the end. yeah noticed that, why I used the rear cam for sound and the front as a main vid... Quote Link to comment Share on other sites More sharing options...
Husky Posted June 5, 2010 Share Posted June 5, 2010 uploading to youtube managed to get quite an eev sound under the number plate so im quite chuffed putting the one there for sound in the mean time eperiment success. on a side note the backbox missing was epic fun and sounded ace from in the cabin but sounded like ASS from the outside Quote Link to comment Share on other sites More sharing options...
andlid Posted June 5, 2010 Share Posted June 5, 2010 uploading to youtube managed to get quite an eev sound under the number plate so im quite chuffed putting the one there for sound in the mean time eperiment success. on a side note the backbox missing was epic fun and sounded ace from in the cabin but sounded like ASS from the outside Quote Link to comment Share on other sites More sharing options...
Husky Posted June 5, 2010 Share Posted June 5, 2010 Quote Link to comment Share on other sites More sharing options...
andlid Posted June 5, 2010 Share Posted June 5, 2010 Quote Link to comment Share on other sites More sharing options...
andlid Posted June 5, 2010 Share Posted June 5, 2010 sounded good IMO. You should keep it that way! You most have loved it I'd say from all the 'blipping' going on on those clips! Can't believe the quality for 10£! What MicroSD card do you use? saw a few 'jumpy' frames.... Quote Link to comment Share on other sites More sharing options...
Husky Posted June 5, 2010 Share Posted June 5, 2010 yeah the blip for the down change to rev match became the habit gained from a previously buggered gearbox, never used to be able to downshift without that blip Quote Link to comment Share on other sites More sharing options...
Husky Posted June 5, 2010 Share Posted June 5, 2010 yeah the micro SD cards are going in the bin, they were cheap EBAY ones that say sandisk but are copies. i bought them before i read all about duplicate frames on cards with poor write speeds got to spend a little more moolah for nice ones before i make a full vid Quote Link to comment Share on other sites More sharing options...
andlid Posted June 5, 2010 Share Posted June 5, 2010 yeah the micro SD cards are going in the bin, they were cheap EBAY ones that say sandisk but are copies. i bought them before i read all about duplicate frames on cards with poor write speeds got to spend a little more moolah for nice ones before i make a full vid Got 4 gb sandisk ones that works perfectly! Quote Link to comment Share on other sites More sharing options...
Husky Posted June 5, 2010 Share Posted June 5, 2010 yeah these have sandisk labels but i know theres no way they are got to order some more decent ones when i get the chance Quote Link to comment Share on other sites More sharing options...
Husky Posted June 20, 2010 Share Posted June 20, 2010 hi all ive got my Mini Video Cameras for £10 today plus a 8 gb tf micro sd for it, i charged it for about 20 mins just to see if it worked and all seemed sell, only got about 2 seconds ov vid, so i put it back to charge, just turned it on to record a better vid but nothing is on the memory card so i used the shutter button to take a pic to see if it was the card and the pics are there but no vids, also when i turn it on the indicator light go off after about a minuet and the add on ebay says 2 hour battery life, link below http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 3351wt_868 can anyone help cheers Niko -when you turn it on it has an auto off feature to save battery if you dont use it within a minute hence the light going off. -when you stop it recording you only need to tap the shutter button once and wait, it will then process and store the file properly, if you press the off button instread it will corrupt the file, i think this may be whats happening? -try charging it for about 35-40mins shouldnt need any more than that as its only a tiny battery Quote Link to comment Share on other sites More sharing options...
Niko Posted June 23, 2010 Share Posted June 23, 2010 hi all ive just done a couple of small vids to test out the camera now i know how it works just put them on the laptop to have a look and the sound is delayed dose anyone know why this is and how to fix it? cheers niko Quote Link to comment Share on other sites More sharing options...
Husky Posted June 23, 2010 Share Posted June 23, 2010 hi all ive just done a couple of small vids to test out the camera now i know how it works just put them on the laptop to have a look and the sound is delayed dose anyone know why this is and how to fix it? cheers niko hmm thats an odd one i dont recall reading anything about mismatched sound but will have a look through my stuff for it Quote Link to comment Share on other sites More sharing options...
andlid Posted June 23, 2010 Share Posted June 23, 2010 sounds like a dodgy player possibly? try virtuadub... Quote Link to comment Share on other sites More sharing options...
Husky Posted June 23, 2010 Share Posted June 23, 2010 sounds like a dodgy player possibly? try virtuadub... agreed, there doesnt seem to be any reports of mismatched vid/aud anywhere Quote Link to comment Share on other sites More sharing options...
andlid Posted June 23, 2010 Share Posted June 23, 2010 sounds like a dodgy player possibly? try virtuadub... agreed, there doesnt seem to be any reports of mismatched vid/aud anywhere virtualdub: http://virtualdub.sourceforge.net/ and VLC: http://www.videolan.org/ Quote Link to comment Share on other sites More sharing options...
