mic-39 Posted April 14, 2010 Share Posted April 14, 2010 Firstly a big thanks to Paul for the works done on Saturday past. I decided a quite a while ago to have the remap works done to my car. There are no mods apart from the jwt air intake and an aftermarket k2 type exhaust As I had other things to be doing at the weekend I set off on Friday night got the ferry and travelled down to Leeds getting there at 3am Got up the next morning and headed over to RS. Paul was working on a cleo 172 on the dyno and after hearing is scream at 7500rpm I got a bit concerned about the Z doing that but thought I was there so I might as well go ahead with it now, half an hour later the Renault was finished and I handed over my keys Truthfully I was really aprehensive about the dynoruns but I quickly learnt that Paul definately knows what he is doing The car was reversed in and strapped down, Paul quickly set about checking the gear ratios and the general set up and after a few runs to check all these set about the initial power runs. Not being an expert at all about these things a few full runs were done and run 4 taken as the average. The initial surprise to me was the stock fuel map--It appeared to be all over the graph and Paul assured me that he would fix that. After what appeared to be an un-ending amount of dyno runs, a lot of tapping and pressing buttons on the laptop I noticed the power levels increasing and the car definately started to sound sharper. Its hard to explain in words but it sounded great beforehand but now was even better. After I think run 25 Paul came out of the car we went out for a think and a smoke . He thought he would alter cam timing and again after a few further runs the power peaked at the 282 flywheel. He said that the stock airbox would achieve further gains and that using higher octane fuel would improve things aswell--Intake temps were getting very high due to the fact that the outside temp on Saturday was 18 degrees and in the unit temps were over 32/34 degrees despite all 4 fans working I believe that the throttle response was atltered to achieve 100% opening and that the revlimiter was increased also. We had to call it a day at lunchtime as the bridgestones were really sticky and hot and this was affecting the final runs-apparently causing drag on the rollers. We finally then got the car out for a road test and immediately the difference was evident, the same car but so different, more responsive sharper and crisper sounding and a lot more drive-able Paul really knows his was around the 350 and I believe a specific car remap is the only way to go I said my farewells then headed off down the M1 to Derby and immediately the first thing I realised was that the fuel economy was between 35 and 36mpg Over the remainder of the weekend with quite a lot of town driving and over 4 tanks of fuel later the average was still over 28mpg. well impressed I would recommend RS and Paul for a stirling job Quote Link to comment Share on other sites More sharing options...
M13KYF Posted April 14, 2010 Share Posted April 14, 2010 great write up, good to hear Quote Link to comment Share on other sites More sharing options...
UNABASHED Posted April 14, 2010 Share Posted April 14, 2010 glad to hear more praise for RS, still on my to do list - especially as I pass them everyday on way to work. Quote Link to comment Share on other sites More sharing options...
mic-39 Posted April 14, 2010 Author Share Posted April 14, 2010 after a 400mile drive motorway, town and a mixture of a and b roads Quote Link to comment Share on other sites More sharing options...
andlid Posted April 14, 2010 Share Posted April 14, 2010 makes me wanna take mine out for a spin Quote Link to comment Share on other sites More sharing options...
narcotix Posted April 14, 2010 Share Posted April 14, 2010 That's a very good review ... It's definitely on my to do list as well ... Quote Link to comment Share on other sites More sharing options...
Tarmac@TarmacSportz Posted April 14, 2010 Share Posted April 14, 2010 Great write up Im only at Derby so its fairly near, is it a standard price ??? Quote Link to comment Share on other sites More sharing options...
docwra Posted April 14, 2010 Share Posted April 14, 2010 Wow - those are some excellent gains. Definitely adding that to the neverending list To check, this is just a standard ECU reflash, right? Quote Link to comment Share on other sites More sharing options...
mic-39 Posted April 14, 2010 Author Share Posted April 14, 2010 NO This is a individual car specific remap. The data on your car is downloaded then tweeked and altered to achieve the maximum tailored to your car. A standard reflash can actually loose you power in certain instances. Every engine is different and everyone's mods are different eg exhaust, intake etc etc I was advised never to go for a "standard" reflash because what may be good for my car may not be good for yours. I would suggest that you give Paul a call regarding specifics Cost is slightly more expensive than a " standard" remap as such but honestly the difference is amazing and truthfully I would rather spend a few extra quid having a specific remap done and as you can see there were 36 runs made also to ensure that everything is in tiptop performance Quote Link to comment Share on other sites More sharing options...
webber Posted April 14, 2010 Share Posted April 14, 2010 Good work I've got mine booked in for next week too Quote Link to comment Share on other sites More sharing options...
andlid Posted April 14, 2010 Share Posted April 14, 2010 makes me wanna take mine out for a spin went for a good spin Quote Link to comment Share on other sites More sharing options...
dcash5 Posted April 14, 2010 Share Posted April 14, 2010 Those figures look low to me? Stock Cars are usually around the 275bhp ATF and 230 ATW? Yours appears to be running down on power on the original runs. Quote Link to comment Share on other sites More sharing options...
webber Posted April 14, 2010 Share Posted April 14, 2010 I'm sure I've read somewhere that RS Tunings dyno tends to read on the low side, the main thing is the difference in the before and after measurements IMO Quote Link to comment Share on other sites More sharing options...
UNABASHED Posted April 14, 2010 Share Posted April 14, 2010 I'm sure I've read somewhere that RS Tunings dyno tends to read on the low side, the main thing is the difference in the before and after measurements IMO +1 Dyno's are really only reliable to test the difference before and after mods or tuning, far from perfect in finding out the exact power figures. Quote Link to comment Share on other sites More sharing options...
mic-39 Posted April 14, 2010 Author Share Posted April 14, 2010 On top of what has been said 1. The jwt popcharger is known to loose hp--approx 5-8bhp but the noise is worth it 2. The car was running 97 ron and not 99 as preferred 3. The ambient temp was quite high and with heatsoak intake temps were in the 30's which will affect power 4. The car has 70k miles also My end goal was not to achieve blistering performance, really if i wanted that i would fit turbos, superchargers etc but really just to fine tune what Nissan have tried to achieve and to make better their shortcomings. I have achieved that for a few hundred quid and it has just made what i believe is a good car better Quote Link to comment Share on other sites More sharing options...
SwanageDave Posted April 14, 2010 Share Posted April 14, 2010 All very good reading and interesting stuff, but me living in the soft south coast what are the cost's and is there anyone nearish to dorset to get it done? my mileage is crap at the moment and could do with a few mor mpg. cheers Dave Quote Link to comment Share on other sites More sharing options...
UNABASHED Posted April 14, 2010 Share Posted April 14, 2010 there's places down south and in midlands that use the same software as RS tuning (I believe RS use the UpRev software?) - have a search through the traders section Quote Link to comment Share on other sites More sharing options...
webber Posted April 14, 2010 Share Posted April 14, 2010 Abbey Motorsport are in Surrey and they use the UpRev software too and are known to be one of the best 350z tuners in the UK Quote Link to comment Share on other sites More sharing options...
SwanageDave Posted April 14, 2010 Share Posted April 14, 2010 Thanks guys Quote Link to comment Share on other sites More sharing options...
docwra Posted April 14, 2010 Share Posted April 14, 2010 This is a individual car specific remap. The data on your car is downloaded then tweeked and altered to achieve the maximum tailored to your car. OK, its not a standalone ECU/chip change/daughter board change then - thats what I was getting at. Any idea what parameters can be changed on a standard ECU - ignition timing, injector etc? Quote Link to comment Share on other sites More sharing options...
Chris`I Posted April 14, 2010 Share Posted April 14, 2010 This is a individual car specific remap. The data on your car is downloaded then tweeked and altered to achieve the maximum tailored to your car. OK, its not a standalone ECU/chip change/daughter board change then - thats what I was getting at. Any idea what parameters can be changed on a standard ECU - ignition timing, injector etc? Search for UpRev, all the details are about. It depends on the year of the car as to what can be done - speak to Abbey or RS Tuning and they can tell you what can be done with your car. Theres no generic maps for these cars as the changes are quite minimal, so the safe window of operation is quite small I would imagine - not like most FI cars where they can generically map them and get good results. Quote Link to comment Share on other sites More sharing options...
SteveW Posted April 15, 2010 Share Posted April 15, 2010 Just seen your post. Yes it was me who was down at RS on saturday it was good to meet you and have a chat about the Zed world. Those are some good gains you've got there I hope I get something similar when funds allow this to be done. This mod is definately on my list and with the increased fuel economy maybe I can justify it sooner than I first thought. I can recommend RS tuning as well Paul is sound and always willing to discuss things with you in detail if you have any questions. The reason I was there on saturday was not for me but for my mate who has an MR2 Turbo. We were there to find out his BHP after a few mods. Made 406BHP at the flywheel it feels awesome! Once again goo dto meet you mate. Thanks Steve Quote Link to comment Share on other sites More sharing options...
RSTuning Posted April 16, 2010 Share Posted April 16, 2010 Firstly a big thanks to Paul for the works done on Saturday past. I decided a quite a while ago to have the remap works done to my car. There are no mods apart from the jwt air intake and an aftermarket k2 type exhaust As I had other things to be doing at the weekend I set off on Friday night got the ferry and travelled down to Leeds getting there at 3am Got up the next morning and headed over to RS. Paul was working on a cleo 172 on the dyno and after hearing is scream at 7500rpm I got a bit concerned about the Z doing that but thought I was there so I might as well go ahead with it now, half an hour later the Renault was finished and I handed over my keys Truthfully I was really aprehensive about the dynoruns but I quickly learnt that Paul definately knows what he is doing The car was reversed in and strapped down, Paul quickly set about checking the gear ratios and the general set up and after a few runs to check all these set about the initial power runs. Not being an expert at all about these things a few full runs were done and run 4 taken as the average. The initial surprise to me was the stock fuel map--It appeared to be all over the graph and Paul assured me that he would fix that. After what appeared to be an un-ending amount of dyno runs, a lot of tapping and pressing buttons on the laptop I noticed the power levels increasing and the car definately started to sound sharper. Its hard to explain in words but it sounded great beforehand but now was even better. After I think run 25 Paul came out of the car we went out for a think and a smoke . He thought he would alter cam timing and again after a few further runs the power peaked at the 282 flywheel. He said that the stock airbox would achieve further gains and that using higher octane fuel would improve things aswell--Intake temps were getting very high due to the fact that the outside temp on Saturday was 18 degrees and in the unit temps were over 32/34 degrees despite all 4 fans working I believe that the throttle response was atltered to achieve 100% opening and that the revlimiter was increased also. We had to call it a day at lunchtime as the bridgestones were really sticky and hot and this was affecting the final runs-apparently causing drag on the rollers. We finally then got the car out for a road test and immediately the difference was evident, the same car but so different, more responsive sharper and crisper sounding and a lot more drive-able Paul really knows his was around the 350 and I believe a specific car remap is the only way to go I said my farewells then headed off down the M1 to Derby and immediately the first thing I realised was that the fuel economy was between 35 and 36mpg Over the remainder of the weekend with quite a lot of town driving and over 4 tanks of fuel later the average was still over 28mpg. well impressed I would recommend RS and Paul for a stirling job It was a pleasure to meet you. I'm glad you are happy with the mapping, as people said the stock run was pretty low but this can be a number of thigs, your fuelling was a mile out so gives me a bit of an easier time finding power haha. It sounds like you had a fun trip on the way back Quote Link to comment Share on other sites More sharing options...
Walbertonio Posted May 26, 2010 Share Posted May 26, 2010 Great review. This has pretty much sold me on the idea of a remap. Due a P3 w/ plugs etc in 1k miles so will wait for that, get the MD spacer coming from Alex fitted, then give them a ring methinks! Quote Link to comment Share on other sites More sharing options...
