ajd82 Posted April 14, 2010 Share Posted April 14, 2010 Alright I need some advise. My car is leaking water. I've taken it to a garage and initially the radiator was leaking. That has been fixed but water still leaking from somewhere. Now the garage are telling me it could be a problem with the water pump. Has anyone has any similar problems? Cheers Quote Link to comment Share on other sites More sharing options...
IanS16 Posted April 14, 2010 Share Posted April 14, 2010 Are you sure its not the aircon thawing? It leaves a puddle on the floor. Quote Link to comment Share on other sites More sharing options...
mic-39 Posted April 14, 2010 Share Posted April 14, 2010 I would have assumed that the water pump would be noisy if it had got to the stage of leaking When you say it is leaking water do you mean that there is water leaking from below or is the radiator level dropping Quote Link to comment Share on other sites More sharing options...
ToffeeZ Posted April 14, 2010 Share Posted April 14, 2010 Are you sure its not the aircon thawing? It leaves a puddle on the floor. As Above. I would check to see if it is coming from your Air/con drain hose. A little water will always drip from the air/con drain if it has been on. Quote Link to comment Share on other sites More sharing options...
