bhavin85 Posted April 10, 2010 Share Posted April 10, 2010 Hi Guys, I picked myself up a second set of facelift headlights the plan originally was to just paint them black and fit them back into the car but now im wondering if I should do something alittle different.... How hard do you recon it would be to wrap this in the CF Vinyl thats about at the moment? The alternative is to make a set of genuine Carbon Inserts which I might do depending on how much it will cost! Thoughts please Quote Link to comment Share on other sites More sharing options...
cfoster Posted April 13, 2010 Share Posted April 13, 2010 Probably fairly easy to do mate but you have the issue with heat from the bulbs shrinking / melting the vinyl. Quote Link to comment Share on other sites More sharing options...
Dene8 Posted April 13, 2010 Share Posted April 13, 2010 Probably fairly easy to do mate but you have the issue with heat from the bulbs shrinking / melting the vinyl. What cfoster said, the lights get very very hot......... would probably cause issues. Genuine CF would be tho' You cracked open the lights yet bhavin, i've got a set i need to get round to modifying? Easy to do? Quote Link to comment Share on other sites More sharing options...
Cragus Posted April 13, 2010 Share Posted April 13, 2010 Pault is your man if your looking for something a little bit special in the light department. If you look in his posts you can see examples of his work - Dreamcustomz Quote Link to comment Share on other sites More sharing options...
bhavin85 Posted April 13, 2010 Author Share Posted April 13, 2010 cfoster - very good point I didnt think of that...with the heat the vinyl will look its elastic memeory and just curly up! Dene8 - I am gonna give the guys that make my strut a call and see what they can do...might do a limited batch of 5 if I can get enough interest but I wouldnt expect them to be cheap Craigus - Thanks bud, ive already talked to paul about this but seeing as I already make carbon bits it makes more sense that I make them myself Quote Link to comment Share on other sites More sharing options...
