ikarus Posted April 4, 2010 Share Posted April 4, 2010 Yeah it will run two of these In what now? i just went out with dad,measured bits then made the awesomeness that is the cardboard template Shaun, i'll model your kicker in BBP and let you know what volume it suggests for best performance. I would go for a single 12" sealed enclosure with the amp that you have. BBP should show us the way bud.. i'll come back to you sortly.. Quote Link to comment Share on other sites More sharing options...
Shaun1982 Posted April 4, 2010 Author Share Posted April 4, 2010 Thanks very much mate Quote Link to comment Share on other sites More sharing options...
andlid Posted April 4, 2010 Share Posted April 4, 2010 Hey man, what type of material do you plan to go for? Quote Link to comment Share on other sites More sharing options...
Shaun1982 Posted April 4, 2010 Author Share Posted April 4, 2010 I will be using mdf andlid Quote Link to comment Share on other sites More sharing options...
andlid Posted April 4, 2010 Share Posted April 4, 2010 I will be using mdf andlid aright, was hoping you'd say fibreglass and you'd be able to let me know how to do it Don't forget to take into account the thickness of the mdf material and that it'll lower the volume all around if you only use surface measures Quote Link to comment Share on other sites More sharing options...
Shaun1982 Posted April 4, 2010 Author Share Posted April 4, 2010 I have had a bit of a play with it before,helped a mate do another mates skyline install. put two 15s in,one each corner of the boot with the amp in the middle.Tis very time consuming Quote Link to comment Share on other sites More sharing options...
ikarus Posted April 5, 2010 Share Posted April 5, 2010 Shaun, i ran the numbers through bbp. I used min and max volume from the S12L7 owners manual and i also used bbp to optimise a volume based on best fidelity. These are the results... Manual recommended minimum (Orange plot line) volume 24.9 ltr F3 55.05Hz Manual recommended maximum (Green plot line) volume 56.6 ltr F3 52.14Hz BBP recommended hi fidelity (Yellow plot line) volume 45.84ltr F3 52.3Hz Plot is sound level (dB) against frequency (Hz). F3 is a measurement used to indicate the lowest audible frquency from a system. *BBP also shows that the S12L7 is more suited to a sealed enclosure than a ported enclosure. So, if it were me i would be looking to build an enclosure with an internal volume of 46 ltr (don't forget about driver displacement - the speaker takes up volume too). I would use an all mdf construction using 18mm sheet all round, but using a double layer for the baffle (the face where the woofer mounts). Hope that helps Quote Link to comment Share on other sites More sharing options...
Shaun1982 Posted April 5, 2010 Author Share Posted April 5, 2010 Cheers Ikarus,im hoping to pop out & get the materials shortly. If i lose 20cm of width then that should bring it down a fair whack shouldnt it?plus the extra volume the sub takes like you said & a double front too Quote Link to comment Share on other sites More sharing options...
Shaun1982 Posted April 5, 2010 Author Share Posted April 5, 2010 Cheers Ikarus,im hoping to pop out & get the materials shortly. If i lose 20cm of width then that should bring it down a fair whack shouldnt it?plus the extra volume the sub takes like you said & a double front too scratch that,i can lose 10cm width. That leaves me a few cm's either side of the sub face still then. Now i need to figure if i can get everything built from one 8x4 sheet from B&Q,then how to get it cut to eliminate wastage plus get it in the back of dads Hyundai coupe Quote Link to comment Share on other sites More sharing options...
andlid Posted April 5, 2010 Share Posted April 5, 2010 Cheers Ikarus,im hoping to pop out & get the materials shortly. If i lose 20cm of width then that should bring it down a fair whack shouldnt it?plus the extra volume the sub takes like you said & a double front too scratch that,i can lose 10cm width. That leaves me a few cm's either side of the sub face still then. Now i need to figure if i can get everything built from one 8x4 sheet from B&Q,then how to get it cut to eliminate wastage plus get it in the back of dads Hyundai coupe Quote Link to comment Share on other sites More sharing options...
ikarus Posted April 5, 2010 Share Posted April 5, 2010 Cheers Ikarus,im hoping to pop out & get the materials shortly. If i lose 20cm of width then that should bring it down a fair whack shouldnt it?plus the extra volume the sub takes like you said & a double front too Np. If you make the box too big then you can fine tune the volume by adding more wood inside. scratch that,i can lose 10cm width. That leaves me a few cm's either side of the sub face still then. Now i need to figure if i can get everything built from one 8x4 sheet from B&Q,then how to get it cut to eliminate wastage plus get it in the back of dads Hyundai coupe I managed all the mdf for my 3 enclosures in an mx5 - took some planning but anything is possible - made good use of B&Q's wood cutting facility though Good luck with it, remember to get some pics up as you go.. Quote Link to comment Share on other sites More sharing options...
Shaun1982 Posted April 5, 2010 Author Share Posted April 5, 2010 Yeah we just did that too.lol. Gonna grab some dinner first then make a start Quote Link to comment Share on other sites More sharing options...
andlid Posted April 5, 2010 Share Posted April 5, 2010 Yeah we just did that too.lol. Gonna grab some dinner first then make a start liking the speed of this project! Get the first pic up asap of progress! Quote Link to comment Share on other sites More sharing options...
Shaun1982 Posted April 5, 2010 Author Share Posted April 5, 2010 Ok guys,im just uploading the pics i took from my blackberry so ill get them up shortly.The box is nearly finished though leaving it overnight for the sealant to go off then it just needs the hole for the sub cut out. I hope your not expecting a piece of art here Hopefully ill get the photos in some sort of order for you Quote Link to comment Share on other sites More sharing options...
Shaun1982 Posted April 5, 2010 Author Share Posted April 5, 2010 Ok lets do this I took some of this and this Then i cut a few of the sections i needed Those then became this then so on up to this stage Next i thought it best that i find out if it still went in its place, fortunately it did So,back in the garage to start making the sides,also adding the speaker connection port Thats todays progress for you peeps,not very interesting i know, ill give you one final photo.........The aftermath Quote Link to comment Share on other sites More sharing options...
yokomo Posted April 5, 2010 Share Posted April 5, 2010 no worse than the mess i just made putting donw the first layers on my fiberglass toneau cover ! wod goes to gether quick too so good progress Quote Link to comment Share on other sites More sharing options...
Shaun1982 Posted April 5, 2010 Author Share Posted April 5, 2010 That took about 5 hours i think Yoko.To be honest as long as the box is sealed fine im not bothered about its looks as its getting covered up at the front & top anyway Having said that though i think making the covers to fit the shape of the strut and the area between the strut & bulkhead will be the hard part Quote Link to comment Share on other sites More sharing options...
yokomo Posted April 5, 2010 Share Posted April 5, 2010 if you just mena to give a flat look wiht out the gaps at the side that shouldnt be to hard , just put some carboard up agaisnt it and draw round to make a demplate. should be both funcational and look quite good once your done , it always looks like cr*p mid way through maing it so your doing pretty well. when i make my fibeglass boxes that look reallllllllllly bad til thyre sanded and covered ! Quote Link to comment Share on other sites More sharing options...
andlid Posted April 5, 2010 Share Posted April 5, 2010 Good work! Gf said: is that stairs he's making Quote Link to comment Share on other sites More sharing options...
Shaun1982 Posted April 5, 2010 Author Share Posted April 5, 2010 Haaaa typical woman comment (puts on flame suit ) My girlfriend was like er wheres that supposed to go.then asked how the sub will go in when it was totally sealed,uni students eh Quote Link to comment Share on other sites More sharing options...
andlid Posted April 5, 2010 Share Posted April 5, 2010 Haaaa typical woman comment (puts on flame suit ) My girlfriend was like er wheres that supposed to go.then asked how the sub will go in when it was totally sealed,uni students eh Quote Link to comment Share on other sites More sharing options...
ikarus Posted April 5, 2010 Share Posted April 5, 2010 That was quick Quote Link to comment Share on other sites More sharing options...
Shaun1982 Posted April 6, 2010 Author Share Posted April 6, 2010 Thanks dude,hopefully i might get some more done today Quote Link to comment Share on other sites More sharing options...
Dblock Posted April 6, 2010 Share Posted April 6, 2010 This might help http://http://www.reaudio.com/speaker_box/LPort_Box_Calc.html Quote Link to comment Share on other sites More sharing options...
Shaun1982 Posted April 6, 2010 Author Share Posted April 6, 2010 Thanks Dblock but the box is done now dude just floors & covers to make now Quote Link to comment Share on other sites More sharing options...
