Facelift air-con knobs
ug45cwb
Looking to freshen up the interior a little, can the 06+ air-con knobs with the aluminium edges be applied to the older models? Anyone know a source for these?
Also, whilst i'm at it, what about the sliding center compartment?
Cheers
Cheers
yes, you will have to swap the whole unit which can be accessed after removing he gear suround section which is clip-on :thumbs: the unit is also clipped on and is plug and play :)
What sliding compartment are you talking about? do you mean the cubby? whats in yours at present. Anyway if its the cubby you can buy these secondhand or new from the stealers ;)
Not as simple as swapping over the heater controls only. You have to replace the entire centre trim from the three-pod gauge surround,the stereo surround, the heater control surround and knobs, gear lever surround, main centre console with ashtray etc, cambus air-con box inside the dash, knee pads and rewire the hazard warning switch.
It can be done, but is expensive.
+1 what he said :thumbs::lol:
