drob Posted March 24, 2010 Share Posted March 24, 2010 as the weathers picking up and im drivin the z more so ive started to notice a few niggles that need fixing 1) drivers window makes a whistle noise seems to come through between the tweeter plastic cover, so is the rubber seal gone? 2) when i change down from 3rd to second say when your approaching a roundabout and carry on and give it some beans, it makes a wurrgh noise. not alot of power gets over 3000rpm and its fine. but the power does seem abit intermitent, any ideas? Quote Link to comment Share on other sites More sharing options...
cookiemonster Posted March 24, 2010 Share Posted March 24, 2010 Second point might be the TC kicking in, if your approaching at speed and down shift you obviously cause the back end to be alittle unstable, TC is bringing it back into line and this prevents you accelerating fully. Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted March 24, 2010 Share Posted March 24, 2010 first problem requires the window reset procedure Quote Link to comment Share on other sites More sharing options...
martinmac Posted March 24, 2010 Share Posted March 24, 2010 The window could respond to a reset, there is a copy of the procedure on here. It sounds like it isnt closing properly which is not uncommon. Quote Link to comment Share on other sites More sharing options...
drob Posted March 24, 2010 Author Share Posted March 24, 2010 no lights come on and i dnt feel the car being stopped by tcs, i can can tell when it does it. just feels boggey like its not delivering power correctly, ive got slight concerns its not engaging gears 100% Quote Link to comment Share on other sites More sharing options...
cookiemonster Posted March 24, 2010 Share Posted March 24, 2010 no lights come on and i dnt feel the car being stopped by tcs, i can can tell when it does it. just feels boggey like its not delivering power correctly, ive got slight concerns its not engaging gears 100% thats strange, the sound you describe is the same as i get if its wet and the tyres are cold. Wouldnt a gear problem be apparent through the feel of the gear stick? Quote Link to comment Share on other sites More sharing options...
drob Posted March 24, 2010 Author Share Posted March 24, 2010 yeah maybe, gear stick seems to vibrate a little but i just put it down to all the power its trying to handle Quote Link to comment Share on other sites More sharing options...
Bradders Posted March 24, 2010 Share Posted March 24, 2010 yeah maybe, gear stick seems to vibrate a little but i just put it down to all the power its trying to handle My gearknob vibrates too. The missus likes it; can't think why. I think is a TADTS of the Z. Evo magazine called one of their test cars, a Sunset, the "Ginger Tingler" Bradders. Quote Link to comment Share on other sites More sharing options...
kazman Posted March 24, 2010 Share Posted March 24, 2010 To prove or disprove the window reset recommendations, try making sure it's all the way up using the switch at the beginning of your journey. I would imagine that will ensure it's all the way up. Then you can see if the whistle stops. I greased the seals on mine and it did the trick. Quote Link to comment Share on other sites More sharing options...
