VSS wire
andis20
Nope, not at all.
I think that to a certain degree, you get too many warnings from the sat nav, just to make sure you make the turn.
For instance when on the motorway, it tells you
"Keep right in three quarters of a mile"
"Keep right in half a mile"
"Keep right in quarter of a mile"
"In 400 feet, keep right"
So you'll have plenty of time and distance to sort yourself out.
Vss wire is at something like pin 27 of the m42 connector to the ac control unit. I did a diy post locating it. Search in the guides section for a head up display diy, it's in there. Would post the Link but am on my iPhone.
Ok thanks marzman, i'll search around for your thread.
Cheers :#3:
Am home now on the lapdog...
Here is the detail, and the link... i was close... :lol:
Now, the VSS wire is found on the middle plug (grey - M49), and is pin 26 - which if you're looking down on it is the top row, 3rd hole from the left. My wire was brown with a white stripe. I found the wiring info in this document - on page 47:
http://www.myzroadster.com/files/2006%2 ... al/atc.pdf
viewtopic.php?f=35&t=18962
