98duffa Posted March 22, 2010 Share Posted March 22, 2010 prob already here but just a quick one. will 30mm springs on standard shocks be ok with 19" rota gtrs. no rubbing etc Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted March 22, 2010 Share Posted March 22, 2010 You'll prolly have to get some rear camber arms and bolts and front A-arms for camber adjustment Quote Link to comment Share on other sites More sharing options...
98duffa Posted March 22, 2010 Author Share Posted March 22, 2010 is it a major issue if it was just standard with a 30mm drop. and will it rub with the gtr 19" Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted March 22, 2010 Share Posted March 22, 2010 Prolly depends more on the offset whether you will rub or not. If you fill the arches to the edge, then you might rub, you might not, best ask the forum low-riders, hehe Quote Link to comment Share on other sites More sharing options...
98duffa Posted March 22, 2010 Author Share Posted March 22, 2010 they are an et20 offset 19" rota gtr Quote Link to comment Share on other sites More sharing options...
Stew Posted March 23, 2010 Share Posted March 23, 2010 I'd have thought et20 would be ok. A lot depends on tyre type too! Different tyres have different physical sizes. I'd give it a go... Quote Link to comment Share on other sites More sharing options...
Chris`I Posted March 23, 2010 Share Posted March 23, 2010 As Stew says, should be fine, give it a go. But budget for camber/toe bolts and possibly A-arms and camber arms, so if you do need them its not a shock. Quote Link to comment Share on other sites More sharing options...
98duffa Posted March 23, 2010 Author Share Posted March 23, 2010 also been considering teins with 17mm drop front and 14mm rear anyone have them fitted. do they make much difference to the look. and the tyres are 245/35 front and 275/35 rear Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted March 23, 2010 Share Posted March 23, 2010 If it helps, this is my car on 19"'s on standard suspension Quote Link to comment Share on other sites More sharing options...
TADDY Posted March 23, 2010 Share Posted March 23, 2010 Ive run 30mm springs on et15 19" wheels with 245 35 tyres and there was loads of room no issues at all Quote Link to comment Share on other sites More sharing options...
98duffa Posted March 23, 2010 Author Share Posted March 23, 2010 any pics come on peeps i know everyone likes being picture whores on here Quote Link to comment Share on other sites More sharing options...
poverty Posted March 31, 2010 Share Posted March 31, 2010 as said above budget for the arms and camber. in the long-run it'll probably work out cheaper to get them done Quote Link to comment Share on other sites More sharing options...
