quick spacer question
Jak
As a lot of you will know from my picture thread last weekend i have recently fitted a set of eibach 20mm spacers.
With the set i used you have to replace the studs - this is something i ended up getting my mechanic to do wihlst e replaced my front discs & pads. When i collected the car he said all had gone well except, and its probably absolutly nothing to worry about, that on the rear hubs the knurled part of the new studs (that sits inside the hub - not the theaded part) protrudes ever so slightly to the outside of the hub . he said it may be worth posting just incase any of you can see any potential issues?
Thanks :thumbs:
Jak
