350 Russ Posted March 6, 2010 Share Posted March 6, 2010 how do you get the cigaretter lighter out? ive tried getting a screwdriver under neath it and pulling it but its not bugding! do i have to remover alot of trim around it? i need to get a switch live and negative feed but i cant find it on the bose stereo, ive spliced into the light green cable but nothing happens, help please Quote Link to comment Share on other sites More sharing options...
Ian Posted March 6, 2010 Share Posted March 6, 2010 Which lighter? I'm assumming the one under dash ? If it is then: 1) remove the 2 10mm bolts 2) pull out cupholder & use flat blade to unclip it 3) remove 10mm bolt from behind cup holder 4) remove 10mm bolt from behind cig lighter 5) remove door sill 6) remove nut in footwell to release kick panel 7) remove final screw & pull away the panel then you will see the cig lighter & can splice into it Quote Link to comment Share on other sites More sharing options...
350 Russ Posted March 6, 2010 Author Share Posted March 6, 2010 theres one under the dash??? i was on about the one behind the seats, cheers ill go have a look Quote Link to comment Share on other sites More sharing options...
Husky Posted March 6, 2010 Share Posted March 6, 2010 are you running a head unit from it? it should be quite simple to find the cable for ground and battery+ on the bose loom. grey is ground pink is live i think? Quote Link to comment Share on other sites More sharing options...
Ian Posted March 6, 2010 Share Posted March 6, 2010 theres one under the dash??? i was on about the one behind the seats, cheers ill go have a look No idea about that one, thats one section of the interior I haven't removed yet Quote Link to comment Share on other sites More sharing options...
UNABASHED Posted March 6, 2010 Share Posted March 6, 2010 I never knew there was one under the dash?? Quote Link to comment Share on other sites More sharing options...
Ian Posted March 6, 2010 Share Posted March 6, 2010 Quote Link to comment Share on other sites More sharing options...
350 Russ Posted March 6, 2010 Author Share Posted March 6, 2010 are you running a head unit from it? it should be quite simple to find the cable for ground and battery+ on the bose loom. grey is ground pink is live i think? ive sorted it now, im running a new sat nav in the place of the old one, i was under under the impression that the light green is live because of what it said in the thread in the ice&electronics section. no matter, its done now! Quote Link to comment Share on other sites More sharing options...
ersen.o Posted March 7, 2010 Share Posted March 7, 2010 under dash? :x Quote Link to comment Share on other sites More sharing options...
