Zugara Posted March 4, 2010 Share Posted March 4, 2010 Is this normal to have condensation on the inside of the head light? Anyone else had this problem? Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted March 4, 2010 Share Posted March 4, 2010 did on a previous car, it means that the light is no longer air tight. if the car is sat up for a hot day, you could take the back of the headlight off and leave it to evaporate out. then seal it up again. not a permanent fix. but helps in the summer. long term fix, you'll need to take the headlight out, split it and reseal it properly. P15ULT should be able to advise on this. Quote Link to comment Share on other sites More sharing options...
Zugara Posted March 4, 2010 Author Share Posted March 4, 2010 did on a previous car, it means that the light is no longer air tight. if the car is sat up for a hot day, you could take the back of the headlight off and leave it to evaporate out. then seal it up again. not a permanent fix. but helps in the summer. long term fix, you'll need to take the headlight out, split it and reseal it properly. P15ULT should be able to advise on this. Would this not be covered under nissan 3 year warranty? Mines 0707 so just in the 3 years. Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted March 4, 2010 Share Posted March 4, 2010 did on a previous car, it means that the light is no longer air tight. if the car is sat up for a hot day, you could take the back of the headlight off and leave it to evaporate out. then seal it up again. not a permanent fix. but helps in the summer. long term fix, you'll need to take the headlight out, split it and reseal it properly. P15ULT should be able to advise on this. Would this not be covered under nissan 3 year warranty? Mines 0707 so just in the 3 years. if its under warranty, nissan will just replace the headlight. Quote Link to comment Share on other sites More sharing options...
