Wookiee22 Posted March 15, 2010 Author Share Posted March 15, 2010 Looking to order my oil cooler this afternoon. Do the sandwich plate connections need to be 90 degree or will straight ones do the job? Quote Link to comment Share on other sites More sharing options...
Wookiee22 Posted March 15, 2010 Author Share Posted March 15, 2010 Looking to order my oil cooler this afternoon. Do the sandwich plate connections need to be 90 degree or will straight ones do the job? Any thoughts anyone? Quote Link to comment Share on other sites More sharing options...
nurrish Posted March 15, 2010 Share Posted March 15, 2010 Ive got straight connectors on mine....... Quote Link to comment Share on other sites More sharing options...
Wookiee22 Posted March 15, 2010 Author Share Posted March 15, 2010 Ive got straight connectors on mine....... Well that does it for me then! That's pretty handy as it was going to cost about 20 quid extra to get 90 degree fittings at both ends. Did you go for braided hoses? Quote Link to comment Share on other sites More sharing options...
nurrish Posted March 15, 2010 Share Posted March 15, 2010 I did yeah......if you can get a 90 degree one i'd go for that as it would make it easier....just wait till you see Quote Link to comment Share on other sites More sharing options...
Wookiee22 Posted March 15, 2010 Author Share Posted March 15, 2010 I did yeah......if you can get a 90 degree one i'd go for that as it would make it easier....just wait till you see I can't wait mate Spoke to Adam at the weekend. Looks like the show is finally on the road - should be shipping on either Wednesday or Thursday. Just trying to tie down the last few bits and pieces now. Will probably go with 90 degree fittings just to save a bit of headache, although I'm prepared for plenty of others! May well go for SPA gauges. Was tempted by the dual-role digital but decided that for stuff like boost/oil pressure that is constantly changing it would just get annoying so I reckon I'll stick with analogue. Looks like it's going to be a busy Easter! Quote Link to comment Share on other sites More sharing options...
nurrish Posted March 15, 2010 Share Posted March 15, 2010 Look forward to seeing your progress Quote Link to comment Share on other sites More sharing options...
Wookiee22 Posted March 15, 2010 Author Share Posted March 15, 2010 Look forward to seeing your progress I'll bet! Expect frantic PM's when I'm sitting on a garage floor in a pool of oil, I've manage to snap off the PS cooler and none of the IC pipes will fit! Quote Link to comment Share on other sites More sharing options...
nurrish Posted March 15, 2010 Share Posted March 15, 2010 I will be on holiday Quote Link to comment Share on other sites More sharing options...
Ian Posted March 15, 2010 Share Posted March 15, 2010 I will be on holiday Fancy coming to South Wales on holiday? I've got a spare room for you Quote Link to comment Share on other sites More sharing options...
nurrish Posted March 15, 2010 Share Posted March 15, 2010 Sounds like fun Quote Link to comment Share on other sites More sharing options...
Ian Posted March 15, 2010 Share Posted March 15, 2010 Will be an easier install than yours I'll even feed you Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 19, 2010 Share Posted March 19, 2010 Does the std Z suffer from high oil temps then? i can understand it on a supercharged or turbocharged engine but is there any real need unless you spend all your time on the track. Quote Link to comment Share on other sites More sharing options...
Ian Posted March 19, 2010 Share Posted March 19, 2010 The 3 of us have s/c installs pending Quote Link to comment Share on other sites More sharing options...
Wookiee22 Posted March 23, 2010 Author Share Posted March 23, 2010 Have come across this: http://www.spa-uk.co.uk/design/productdetails/?objid=130 It's a dual oil temp / pressure gauge. Looks good, however my concern is whether its being digital will drive me mad with constantly changing values - for the pressure at least. Also, this won't provide the at-a-glance problem identification that an analogue gives, however it does have an alarm facility. My feeling is that I may go with a straightforward oil temp analogue gauge and just leave the stock pressure gauge, which I imagine is good enough to let me know if there's a real problem. Thoughts? Quote Link to comment Share on other sites More sharing options...
Ian Posted March 23, 2010 Share Posted March 23, 2010 I can't see there being a problem using the stock oil pressure gauge Where are you mounting them? Centre, A-pillar or steering wheel? Quote Link to comment Share on other sites More sharing options...
Wookiee22 Posted March 23, 2010 Author Share Posted March 23, 2010 I can't see there being a problem using the stock oil pressure gauge Where are you mounting them? Centre, A-pillar or steering wheel? Either going in the dash cubby a la Nurrish or potentially in a single din housing, as my stereo is also single din. Quote Link to comment Share on other sites More sharing options...
Ian Posted March 23, 2010 Share Posted March 23, 2010 http://z-store.co.uk/index.cfm?fuseacti ... rentCat=32 Bit expensive though Quote Link to comment Share on other sites More sharing options...
Wookiee22 Posted March 23, 2010 Author Share Posted March 23, 2010 http://z-store.co.uk/index.cfm?fuseaction=product.display&product_ID=8816&ParentCat=32 Bit expensive though Just a bit! Was thinking more along the lines of mounting my (hopefully soon to arrive) AEM UEGO, along with boost and oil temp gauge in a din mounting bracket. Could possibly mount boost where the voltmeter currently sits though. Quote Link to comment Share on other sites More sharing options...
