jacr87 Posted March 2, 2010 Share Posted March 2, 2010 Mechanical Engine Name VQ35DE Cam Design DOHC Orientation Longitudinal Cylinders / Configuration V6 w/ Continuous Variable Valve Timing Control System (CVTCS) & Molybdenum coated pistons Block / Head Composition Aluminum/aluminum Displacement (liters) 3.5L Horsepower 287 @ 6,200 RPM Torque (lbs/ft) 274 @ 4,800 RPM Bore & Stroke (mm) 95.5 & 81.4 Compression Ratio (:1) 10.3 Maximum Engine Speed 6,600 RPM Induction System Sequential multi-point electronic fuel injection Valvetrain 4-valves-per-cylinder Engine Cover Standard Engine Mounts (3 mounts per vehicle) 2 liquid filled; 1 rubber Recommended Fuel Premium unleaded Emissions System Closed loop feedback system w/ 3-way catalyst Emission Certification Level LEV Exhaust Dual (single each side) Electrical Ignition System Electronic, Nissan Direct Ignition System (NDIS) Starter 1.4KW Reduction Alternator 110 Amp. Battery 12 Volt Transmission and Drive System Drive configuration Mid-mounted front-engine / rear wheel drive Transmission Type 6-speed manual 5-speed auto w/ manual mode Standard (Base, Enth, Touring 6MT, Track) Standard (Touring 5AT) Optional (Enth) Gear Ratio 1st 2nd 3rd 4th 5th 6th Reverse M/T A/T 3.794 3.540 2.324 2.264 1.624 1.472 1.271 1.000 1.000 0.834 0.794 N/A 3.446 2.370 Final Drive Ratio 3.538 3.357 Drive Shaft Carbon Fiber Reinforced Plastic (CFRP) Viscous-Limited Slip Differential Standard on all models but Base Vehicle Dynamic Control Standard on Perf, Touring 6MT and Track models Brakes Standard (Standard on all except Track) . Front . Type Vented Disc, 2 caliper pistons Rotor size diameter and thickness (in.) 11.65" x .95" Rear . Type Vented Disc, single caliper piston Rotor size diameter and thickness (in.) 11.50" x .63" Brembo (Standard on Track) .. Front Type Vented Disc, 4 caliper pistons Rotor size diameter and thickness (in.) 12.76" x 1.18" Rear Type Vented Disc, 2 caliper pistons Rotor size diameter and thickness (in.) 12.68" x .87" Brake Assist Standard Brake Control Power-assisted (vacuum) ABS Standard Number of Wheels 4 Number of Channels 4 Number of Sensors 4 Electronic Brake force Distribution (EBD) Standard Parking Brake Hand operated along left side of center console Steering Type Engine speed sensitive power rack-and-pinion Power Assisted Standard Overall Ratio 15.9 Turns (lock to lock) 2.6 Turning Diameter (curb to curb, in feet) 35.33 Turning Diameter (wall to wall, in feet) 37.27 Steering Wheel Tilt Telescopic 3-spoke design w/ air bag Manual N/A Suspension Front Independent multi-link aluminum suspension Front Strut Tower Bar Standard Stabilizer Bar Standard Rear Independent multi-link aluminum suspension Integrated Strut Tower Brace Standard Stabilizer Bar Standard Body / Chassis Type Unibody Materials (primary) Corrosion resistant and high strength steel Hood Aluminum Rear Hatch Steel Exterior Wheels & Tires Base Enth. Perf. Track Touring 5AT Touring 6MT Wheels Aluminum-alloy (7-spoke) FR: 17"x7.5" RR: 17"x8" S S N/A N/A S N/A Aluminum-alloy (6-spoke) FR 18"x7.5" RR: 18"x8" N/A N/A S N/A N/A S Super light Aluminum-alloy (6-spoke) FR: 18"x8" RR: 18"x8.5" N/A N/A N/A S N/A N/A Tires Bridgestone Summer tires - Front 225/50R17 94W, Rear 235/50R17 96W S S N/A N/A S N/A Bridgestone Potenza RE 040 Summer Tire — Front 225/45R18 91W, Rear 245/45R18 96W N/A N/A S S N/A S Spare Tire Temporary (steel) Non-Brembo equipped models S S S N/A S S Temporary (steel) Brembo equipped Track Package N/A N/A N/A S N/A N/A Location Trunk Lights Headlights Halogen Headlamps S N/A N/A N/A N/A N/A Flush mounted, Low: xenon HID, Hi: Halogen N/A S S S S S Interior Seating Base Enth. Perf. Track Touring 5AT Touring 6MT Capacity 2-seater Sport Seat Cloth S S S S N/A N/A Leather N/A N/A N/A N/A S S Type Bucket Heated Seats N/A N/A N/A N/A S S Driver Seat Cloth — 6-way manual S S S S N/A N/A Driver Seat Leather — 4-way power, 2-way manual N/A N/A N/A N/A S S Passenger Seat Cloth — 4-way manual S S S S N/A N/A Passenger Seat Leather — 2-way power N/A N/A N/A N/A S S Memory System N/A Passenger seat back fold down function S Seat back pocket (passenger seat) S Audio . Head unit and speakers . 160W AM/FM/CD w/ 6 speakers (w/ digital clock) S S S S N/A N/A 240W Bose® audio with cassette/6CD in-dash/AM/FM/CD changer control (w/ digital clock) N/A N/A N/A N/A S S Radio Data System (RDS), Bose only N/A N/A N/A N/A S S Bose AudioPilot™ noise-compensation, Bose only N/A N/A N/A N/A S S DVD navigation system N/A N/A O O O O Instrumentation Meters/Gauges Speedometer Tachometer Coolant temperature Fuel level LCD dual trip odometer Standard 3-Bay Gauges Drive computer Tire pressure monitor (Perf, Track, Tour 6MT) Oil pressure gauge Voltmeter Oil temperature Standard Indicators Clock Standard M/T shift up timing indicator (light) When equipped with 6MT A/T indicator When equipped with 5AT Cruise Control N/A with Base model Overdrive off N/A TCS off Enth, Tour 5AT VDC off Perf, Track, Tour 6MT Safety and Security Passenger Restraint Systems Air bags (SRS) Driver (dual stage with seat belt sensors) Standard Passenger (dual stage with seat belt sensors) Standard SRS side & curtain air bags, driver/passenger Optional Outboard seat belts, front 3-point (ALR/ELR for passenger, ELR for driver) Seatbelts with pretensioners and load limiters Standard Tether anchorage Standard Power window lockout button Standard Passive Safety Front crumple zones Hood buckling creases and safety stops Rear crumple zones Body side reinforcements Shift interlock system AT Clutch interlock system MT S Security Steering wheel locks when key is removed Vehicle security system Immobilizer S Dimensions Exterior (inches) Wheelbase 104.3 Overall length 169.6 Overall width 71.5 Overall height 51.9 Tread width Front 60.4 Rear 60.8 Coefficient of drag (Cd) 0.30/0.29 Track model Interior (inches) Head room 38.2 Leg room 42.6 Hip room 53.9 Shoulder room 53.6 Cargo volume VDA rating 8.3 cubic feet SAE rating 6.8 cubic feet Weights Base Enth Perf Track Tour 5AT Tour 6MT Curb (pounds) MT 3,188 3,197 3,217 3,225 - 3,247 AT - 3,210 - - 3,239 - Weight distribution (%) Front/Rear 53/47 GVWR 3815 Volume (cubic feet) Passenger compartment 50.5 Cargo 6.8 Total 57.3 Fuel Economy City AT MT 19 20 Highway AT MT 26 26 Classification 2-door coupe Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted March 2, 2010 Share Posted March 2, 2010 Horsepower 287 @ 6,200 RPM ???? Quote Link to comment Share on other sites More sharing options...
