magic84 Posted February 28, 2010 Share Posted February 28, 2010 can anyone help, whilst driving today the air bag light came on and now flashs all the time, not sure if its a connection. thanks Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted February 28, 2010 Share Posted February 28, 2010 Check under the seat for a dislodged connection then follow the reset procedure which is logged on here and in the manual ......... it's a common problem but there is a solution ............. it's just a bit annoying to have to cope with it ...... someone will come along and point you in the right direction shortly I'm sure Quote Link to comment Share on other sites More sharing options...
magic84 Posted February 28, 2010 Author Share Posted February 28, 2010 ive just been looking on the net for a way to turn it off, and found this video. ive tryed it, and it worked http://www.vehix411.com/category/airbagsrs/page/10/ hope it helps Quote Link to comment Share on other sites More sharing options...
M13KYF Posted March 1, 2010 Share Posted March 1, 2010 ive just been looking on the net for a way to turn it off, and found this video. ive tryed it, and it worked http://www.vehix411.com/category/airbagsrs/page/10/ hope it helps there is the same guide in the GUIDES subforum If problem does come back you may have a broken wire in the seat loom in the back of the seat due to the loom being trapped against the seat frame. I had this problem. Simply repair the broken wire and job sorted. Quote Link to comment Share on other sites More sharing options...
magic84 Posted March 1, 2010 Author Share Posted March 1, 2010 ha oops, still finding it hard to navigate the site! need a sat nav i think. but ill get there one day. but will def do that if it keeps happening Quote Link to comment Share on other sites More sharing options...
stanski Posted March 1, 2010 Share Posted March 1, 2010 - just put some black tape over the light in the cluster like they do on old VW Polo's- you will be fine! Quote Link to comment Share on other sites More sharing options...
M13KYF Posted March 1, 2010 Share Posted March 1, 2010 ha oops, still finding it hard to navigate the site! need a sat nav i think. but ill get there one day. but will def do that if it keeps happening if it keeps happening then is more likely a trapped wire as I had, this will eventually fail altogether but simple to fix Quote Link to comment Share on other sites More sharing options...
