Window drop?
mab1
Hi all,
Bit of advice please - I have a very slight water leak coming in at the bottom of the passenger door on my MY06. On investigation it looks like the window is not moving back up into position when the door is shut, hence not making a tight seal.
I can hear the mechanism making the usual noise when the door is shut, it just doesnt move the glass when the door is opened or closed.
Its in for a service next week, so I will get this fixed then hopefully - has anyone had this problem?
Cheers
you may find that just treating therubber may help the window to go up fully if its a big aged. Some memebers have found this helpful in rubber treatment
The product used to treat the window rubbers is Gummi Pflege. You can find it on ebay
