quick spacer question...
UNABASHED
are the Eibach spacers specific for front or back wheels?
The reason I ask is I want 20mm for the fronts but I am undecided if I want 20mm or 25mm for the rears.
Best way to find out which I want is to buy a set of 20mm spacers and put them on the back to see if they look good enough. If I still want 25mm then I can put the 20mm's on the front a buy a set of 25mm for the rear, and if they look fine I can just but another set of 20mm and put then on the front. (I think that makes sense! :blink: )
I assume that the car will rubn fine if i run spacers on the back before putting them on the front?
Also, feel free to post pics of the rears with 20mm and 25mm - you know you want to! :snack:
ok I think I'm going to just got for 25mm at back and 20mm at front, measured the gap last night and there is much more a gap at the abck than at the front anyway so in the end sdhould even things out nicely.
Next question...
With the Eibach spacer there are different 'systems'. Now, I want the most simplist to use and from what I gather this is the system 4's - is that correct?
