kevgreen16 Posted August 13, 2006 Share Posted August 13, 2006 hi to all, does anyone know the best way of removing the front and rear nissan badges so i can fit my new z ones, i have been told to pour hot water on them but am not sure bout that ????? thanks kev Quote Link to comment Share on other sites More sharing options...
Bluffy Posted August 13, 2006 Share Posted August 13, 2006 Hi see the guide that Val put on: http://www.350z-uk.com/forum/viewtopic.php?t=1632 Quote Link to comment Share on other sites More sharing options...
mugwump Posted August 13, 2006 Share Posted August 13, 2006 Please would someone explain the following statement from that guide..... Note 350Z coupe rear Z badge leaves 2 holes if taken off, 350Z badge itself doesnt Which badge is it that leaves 2 holes? The central nissan one or the "350z" one on the left? I'm confused (easily done) Quote Link to comment Share on other sites More sharing options...
Sarnie Posted August 13, 2006 Share Posted August 13, 2006 Please would someone explain the following statement from that guide..... Note 350Z coupe rear Z badge leaves 2 holes if taken off, 350Z badge itself doesnt Which badge is it that leaves 2 holes? The central nissan one or the "350z" one on the left? I'm confused (easily done) The Nissan one in the middle leaves the holes Quote Link to comment Share on other sites More sharing options...
mugwump Posted August 13, 2006 Share Posted August 13, 2006 Thanks Sarnie, so is there a different method to remove then? I assume the two holes are left because of some kind of through-body fixing? Do I need to "undo" something from inside the boot or is it just a push fit item? Clearly whatever I replace it with will cover the holes but it does mean if I wanted a debadged look I have to fill them and paint... Quote Link to comment Share on other sites More sharing options...
Sarnie Posted August 13, 2006 Share Posted August 13, 2006 Thanks Sarnie, so is there a different method to remove then? I assume the two holes are left because of some kind of through-body fixing? Do I need to "undo" something from inside the boot or is it just a push fit item? Clearly whatever I replace it with will cover the holes but it does mean if I wanted a debadged look I have to fill them and paint... Centre badge is just a push fit, no through body fixing. If you want a debadged look you will have to fill the holes unless you have a roadster which has no hole Quote Link to comment Share on other sites More sharing options...
mugwump Posted August 13, 2006 Share Posted August 13, 2006 Thanks Sarnie top man, thats just what I wanted to know. I cant believe the things people say about you on here, you dont deserve it! Quote Link to comment Share on other sites More sharing options...
Liam's Z Posted August 13, 2006 Share Posted August 13, 2006 Thanks Sarnie top man, thats just what I wanted to know. I cant believe the things people say about you on here, you dont deserve it! Don't know why it's only me who likes him Quote Link to comment Share on other sites More sharing options...
Removed Posted August 13, 2006 Share Posted August 13, 2006 how to over complicate things, by mugwump Quote Link to comment Share on other sites More sharing options...
Sarnie Posted August 13, 2006 Share Posted August 13, 2006 Thanks Sarnie top man, thats just what I wanted to know. I cant believe the things people say about you on here, you dont deserve it! Don't know why it's only me who likes him And its only me who who likes you Quote Link to comment Share on other sites More sharing options...
Liam's Z Posted August 13, 2006 Share Posted August 13, 2006 Quote Link to comment Share on other sites More sharing options...
Removed Posted August 13, 2006 Share Posted August 13, 2006 I like Liam too now let's not get too carried away... Quote Link to comment Share on other sites More sharing options...
Sarnie Posted August 13, 2006 Share Posted August 13, 2006 Quote Link to comment Share on other sites More sharing options...
Liam's Z Posted August 13, 2006 Share Posted August 13, 2006 I like Liam too now let's not get too carried away... Quote Link to comment Share on other sites More sharing options...
Sarnie Posted August 13, 2006 Share Posted August 13, 2006 I like Liam too Cheers Quote Link to comment Share on other sites More sharing options...
Bluffy Posted August 13, 2006 Share Posted August 13, 2006 Please would someone explain the following statement from that guide..... Note 350Z coupe rear Z badge leaves 2 holes if taken off, 350Z badge itself doesnt Which badge is it that leaves 2 holes? The central nissan one or the "350z" one on the left? I'm confused (easily done) There are also two holes under the Nissan Burger on the front.. I guess you are fitting the Z ones that are the same shape as the Nissan Burger?? coz if you look at the back of the badge you will be able to see the two plastic bits that fit into the holes.. Quote Link to comment Share on other sites More sharing options...
kevgreen16 Posted August 13, 2006 Author Share Posted August 13, 2006 Hi see the guide that Val put on: http://www.350z-uk.com/forum/viewtopic.php?t=1632 thanks for that i will give it a try Quote Link to comment Share on other sites More sharing options...
mugwump Posted August 13, 2006 Share Posted August 13, 2006 how to over complicate things, by mugwump I aim to please Want anything over complicated? You know where to come.... Thanks for the info on this though guys, I know I am being pedantic, just want to be sure of what damage I might be doing to my car before I start ripping things off it. PS: Liam, Sarnie, GET A ROOM! Quote Link to comment Share on other sites More sharing options...
M13KYF Posted August 13, 2006 Share Posted August 13, 2006 It might sort out their sexual tension Quote Link to comment Share on other sites More sharing options...
mugwump Posted August 13, 2006 Share Posted August 13, 2006 I guess you are fitting the Z ones that are the same shape as the Nissan Burger?? coz if you look at the back of the badge you will be able to see the two plastic bits that fit into the holes.. Not get em yet m8, have joined the group buy on here to source them, guess thats why I have all the questions. Thanks again. Quote Link to comment Share on other sites More sharing options...
Liam's Z Posted August 14, 2006 Share Posted August 14, 2006 PS: Liam, Sarnie, GET A ROOM! Quote Link to comment Share on other sites More sharing options...
Jacko Posted August 14, 2006 Share Posted August 14, 2006 Just to confirm. The badges supplied by Funkystying, don't have the mounts that go through the holes on the rear of the car. When I took my front badges off, then there were no holes on the front. If Bluffy has done his and his car had them, then they must have changed it for the 06 model. Either way, it doesn't matter as the badges are flat...... no plastic mounts. Quote Link to comment Share on other sites More sharing options...
Mathys Posted August 15, 2006 Share Posted August 15, 2006 I don't think the 03-05 Z has holes in the front???!? Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted August 15, 2006 Share Posted August 15, 2006 Neither do I - certainly none on mine Quote Link to comment Share on other sites More sharing options...
Sarnie Posted August 15, 2006 Share Posted August 15, 2006 I don't think the 03-05 Z has holes in the front???!? No holes in the front mate Quote Link to comment Share on other sites More sharing options...
